Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
What is wrong when a kenmore vacuum cleaner 360 brush roller will not turn but the motor is fine? There are no strings caught.
SOURCE: I HAVE A KENMORE PROGRESSIVE
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
