Lexmark X75 All-In-One InkJet Printer Logo
Question about Lexmark X75 All-In-One InkJet Printer
Are there Lexmark x75 drivers available for
Are there Lexmark All in One x75 drivers available for Windows 7? If so, where can they be found, other than the lexmark website, the printer is not even listed
Posted by pvizzy on
Anonymous
    President:
  • 1,185 Answers
If available they will be on www.lexmark.com support , download
Posted on Feb 28, 2010
I bought this nprinter lexmark x75 at garage sale.. come to find out it is missing the software.. can the disk to install be purchased somewhere ?
the driver is still available for free download on the support site ..but the issue with this printer is that it do not have any drivers for windows vista and windows 7 ..The only available drivers and software on the site are for windows xp and older ..So ..if you want to use it you will need to attach it to a widows xp computer ...I know for sure cause I encountered this issue before and looked for drivers a long time without solution ..
You may try to run the driver in compatibility with windows xp in vista or 7 ..but this will require to change its properties and will have no warranties will work ....
here is the support site and downloads available for xp ..
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X75&segment=SUPPORT&userlocale=EN_US&frompage=null#1
2helpful
I just bought a windows 7 computer yesterday. A Pavilion dm4. It says the driver is not compatible so I am unable to use the printer. Is there a driver update to for my Lexmark X74-X75 all in one printer...
I regret to inform you that the Lexmark X74-X75 All-In-One printer is not compatible on Windows 7 operating system. Please contact Lexmark Technical Support Center for other options.
Lexmark X75.........computer can read the scanner but not the printer
Please ensure that the Lexmark X75 printer driver is properly installed on your computer. You can download and install the X75 printer driver by visiting the Lexmark website at http://bit.ly/iSpJjv. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Note: The Lexmark X75 printer is not compatible with Vista and Windows 7.
1helpful
How can i use my lexmark X74 X75 All In one on Windows operating system
Support information the X75 printer can be found here.
Support information the X74 printer can be found here.
On these page are a link to Windows 7 Information; if you open you will find that Lexmark does not support your printer for Windows 7.
There are no Windows drivers available for the X75; however drivers for Windows, 2000, 98, Me and XP (32-bit) are available for the X74 and these will probably work for the X75.
If your operating system is one of the above check under the tab labelled Downloads; select your operating system to download your driver and save in a known location.
When you connect your printer Windows will try to install but you should be prepared to point to the driver location. If the printer doen not autoinstall you will have to add your printer manually through the Printer section of your Control Panel.
10helpful
Can I install Lexmark X74-X75 All in one printer to windows 7
Hi!
I have checked with Microsoft Windows 7 Compatibility & Lexmark websites & they both said that the driver is not compatible with Windows 7. I dont know if Lexmark will release a driver for windows7.
I have windows xp x64 and can't find compatible drivers for my x75 all in one
> can't find compatible drivers for my [Lexmark X75]
Neither can I.
I accessed the manufacturer's web-site: http://support.lexmark.com
and entered 'X75', and clicked 'downloads',
and found drivers for Mac OS and for Windows 98/2000/XP, but none _explicitly_ for Windows XP 64-bit.
So, either Windows XP 64-bit "natively" supports the printer, or Lexmark does *NOT* support this "legacy" printer in newer Operating Systems (64-bit, Vista, Windows 7).
2answers
I need lexmark X75 printer driver for window 7.
If your printer is not listed on Lexmark's web-site:
http://support.lexmark.com/index?page=content&id=OS3&locale=EN&userlocale=EN_CA
then either:
* the device-driver is included in Windows 7;
* Lexmark does not supply a device-driver for Windows 7.
I have been given a lexmark x75, with no instructions how do i install this
It would be better if you install the software/driver first in your computer. The software also shows you the instructions on how to setup the printer itself. Here are the drivers available for download in the Lexmark website. Just click on the driver compatible with your computer's operating system.
- Lexmark X75 AIO Printer driver for Mac OS X, Mac OS X 10.1, Mac OS X 10.1.5, Mac OS X 10.2, Mac OS X 10.2.1, Mac OS X 10.2.8, Mac OS X 10.3.x, and Mac OS X 10.4.x.
- Custom Driver for Microsoft Windows 2000
- Driver for Microsoft Windows XP
These are the only available drivers. That means the printer is not compatible with Mac 10.5, Mac 10.6, Windows Vista and Windows 7.
For additional information, here's the Setup Sheet (Lexmark X74, X75) and the User's Guide (Lexmark X74, X75) . Hope this helps.
3helpful
2answers
Need windows 7 drivers for a Lexmark X75, where can I find them
Unfortunately, the printer is not compatible with Windows Vista and Windows 7. There are no printer drivers compatible with these operating systems. For Windows operating system, the printer is only compatible with Windows 98, XP, ME and 2000. Hope I can assist you more on this.
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
