I tried to clean my oven today. When I started the process an error
code comes on the screen. E1 F5. What is this and how do I fix it.
Thank You
Hi
I have found the code for you and hoe this gets you no the right track.Let me know how it goes.
F5
Relay
safety circuit
failure
Check oven temperature sensor circuit for
intermittent
high resistance.
· Check lock circuit
· Press Clear/Off and
reprogram
control. If code reappears, replace control
Note: If all above check OK the F5 code can be a
result of
a momentary loss of power (Do NOT replace control or
lock,
check lock circuit)
Thank you for writing to fix ya.
Best Regards Richard
SOURCE: E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press
the up arrow( ^ ). The panel will appear 3:00 (indication for the
duration of self-cleaning). The oven will lock on its own and start the
self-cleaning.
This code means the control has detected a problem with the door latch
switch. Switch is defective and needs replaced. Part # is W10107820 and
cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and
turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
SOURCE: Whirlpool Self Cleaning oven error code
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Assuming the door is still locked after cooling, then either the door switch is bad or the wiring from the control panel to the door switch has a problem. First disconnect the power from the oven. Then check the wiring and connectors (from the control to the switch and back). If those are fine, you need to replace the door switch. After replacing the switch or fixing any bad wiring/connections, reconnect the oven to power. Press and hold any key on the panel for at least one minute to clear the error. You should see F2 on the LCD panel. Press Cancel to clear the error then check to see if any new error (or the old one) message occurs. (Usually a new error message will come up within a minute.)
Which model Whirlpool oven do you have? If you add a comment with the model number, I may be able to provide a parts list and diagram of the unit.
I hope this helps.
