Lands Phones Logo
Posted on Feb 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone says no link to base phone stop working
No link to base phone stop working phone is charged press talk and phone sayt move closer to base.
Anonymous
Level 3:
  • Master 337 Answers
  • Posted on Feb 28, 2010
Anonymous
Master
Level 3:
Answers
337
Questions
0
Helped
133717
Points
1057
Try unplugging the base unit and plugging it back in again. This is not guaranteed to help but has worked in the past.
I have Panasonic kxtc1237sud. When I press the talk button, the following message is displayed "No link to base ..." How can I link the hand set with the base? Thanks!
follow the procedure to register the hand set to the base ( all in the user manual)
get closer to the base ,
change the battery --too low to send a strong signal
move away from metal walls etc
no link means not wireless connection
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
When I press the talk button it says: No link to base. Move closer to base. Try again
Hand each phone up on the base and it will marry it. If you continue to have no link to base make sure everything is plugged in correctly. If it persists you probably have a defective phone.
1helpful
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
1helpful
2answers
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
1helpful
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
3helpful
2answers
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
