Soap Injector Not Working Properly
When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following: 1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed. 2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting. 3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector. 4. If you have an adjustable nozzle, be sure it is in the low pressure position (away from the gun) to draw soap.
Interchangeable Tips
Your machine is supplied with either interchangeable tips or a multi-reg. Your machine is supplied with interchangeable spray tips. The black tip lowers your pressure and draws chemical. The other tips are for high pressure rinse at different spray angles. Red is 0 degree, yellow is 15 degree, green is 25 degree and white is 40 degree. The yellow tip is used for most standard applications. Be sure the quick coupler is fully engaged before pulling the trigger gun. Failure to do may result in the tip becoming a projectile and may be lost or damage to property or persons may occur.
William, 1999 Dodge Durango, years for drivers door interchange are 1998 to 2000. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kevin, use the links below to find Mazda hood interchange.
Hi, sometimes the wire gets stuck when feeding through at the lip on the welding electrode tip. Try unscrewing the welding tip on the end of the welding hand piece to make sure the wire is not getting stuck there. If the wire come through with the tip removed, then screw the tip back on over the wire. Withdraw the wire and then see if the wire will initially feed through a meter or two untill it hits the welding tip.
Grab a paper clip and locate the small hole that is on the face of the outside edge of your optical drive (CD Player) Press the tip of the paper clip into that little hole and the CD drive will pop open allowing you to remove the CD.
Your camera is a point-and-shoot camera styled to look like a DSLR. Your lens does not come off. If you want interchangeable lenses, you need to step up to a DSLR camera.
Follow these all tips :
1. Plz remove unwanted Software
2. Install good Licensed Antivirus and scan whole computer
3. Try it Start > Run > type msconfig > enter > in startup option plz uncheck few programmes.
4. Click on My Computer > C: drive > properties > clean disk > OK
This is called BEZEL you want to lift off. Take watch case opener (or just a pocket knife), insert the blade between case and bezel, then carefully pry up bit by bit, going all around the case. Make sure you are pressing blade in while prying up the bezel. This will not let knife to slip and scratch the watch.
Rate me, plz.
