Car Audio & Video Logo
Posted on Feb 28, 2010
IPOD not recognized as input source
The marine radio does not recognize my ipod as an input source. It recognizes the cd,and even charges the ipod . This is kenwood model 225-mr
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
376
Points
You probably need a firmware update. I had the same issue with my DDX512. http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
I can't get my radio to recognize my ipod
im having this problem too,do you have one of the new ipods,i believe the alpine cda9883 is 2007 model,so i think the reason the ipod wont work is that its too new and the alpine dont recognize it,maybe you can try getting an older version of itunes not the new itunes9
Alpine cda- 9883 radio will not recognize ipod
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from itunes.com .....good luck
My computer will not recognize my Ipod when plugged into the USB
do you have itunes installed ? if not install itunes and if so try and see if it is recognized on another computer if it is seen by another computer try and uninstall the software on your system and update and reinstall it
4helpful
2answers
My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
Try the link below that applies to your computer OS:
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_3_for_Mac
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
Useful troubleshooting-video:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
Not recognizing the iPods or charging.
i had the same problem. make sure that there isnt any pocket lint in the ipod. also make sure that nothing is bent.
2answers
Have you tried installing the ipod program cd from your ipod on a separate file. Under a different username? It may be conflicting with the older model ipod protocols. If that dosen't work try going to apple.com for further assistance.
My itunes won't recongise my ipod
try a program called sharepod see if that works.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
