Question about Nokia 5530 XpressMusic Smartphone
How do I repeat message tone? An incoming message generates a tone but thats it - if I dont pick up the message for a while it doesn't repeat the tone to remind me....
Posted by pat_holbrook on
Anonymous
    New Friend:
  • 46 Answers
Play it many time...
Posted on Feb 28, 2010
Uniden d1680 answering machine doesn't record messages, only dial tone.
If the system doesn't answer the call at all then you need to turn the answering system on. If it answers the call but does not record a message then you need to turn "Announce Only" off. Both of these are in the Answering System Menu options described on page 13 of the manual.
Apr 18, 2012 | Uniden D1680-3
Can i change the message tone on my samsung genio touch
1.go to settings 2.go to phone profiles 3.pick normal profile for example and u can c the arrow next to it 4.touch the arrow 5.then, c upper right where it writes incoming call, touch it, then got other 2 options, touch the second one which is new message 6.after that c the second tab where it writes message alert tone 7.then,if u dont want any of those ready made message tones, touch sounds tab on the bottom right...
the end...
Sep 12, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Change message tone
click on settings>phone profiles>click on the 2 red arrows on the one u want to change>in the drop down box at the top change from incoming to new messages. then pick the sound u want as ur new message tone then save
Oct 13, 2009 | Samsung Cell Phones
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
I don know how to change my messaging tone on my sidekick lx
to change txt message tone:
go to text message main screen then press the top left button.scroll down to settings and click. then scroll down and ull see "new message alert" and there u go.
to the same for picture messaging.
ring tone:
go to phone
click the top left button
scroll down to settings, then general
scroll down the incoming call. and clik on that and u will have options
May 17, 2009 | Sharp Sidekick LX Smartphone
Picking up messages remotely
Try this...
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Dec 12, 2008 | GE 25942GE2 Cordless Phone System
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Nov 07, 2007 | Nokia N73 Cellular Phone
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Nokia 5530 XpressMusic Smartphone Logo
100 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
matt
matt
