Or just plug the video lead into the onboard connection (vga) if that doesnt work try hitting f1 when your pc is loading as sometimes the bios may be set to run in pci (graphics card) but will tell you at startup to press f1 to continue but you wont be able to see that message as its still in vga mode at this point ? i hope you understand me sorry lol, on my pc i hit f1 after 1 minute of loading to allow the computer time to get to the loading screen (which we cant see) then i know that when i press F1 the screen pops into life after about 15 seconds try it
The monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
SOURCE: Analog Power Saving Mode
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: http://us.lge.com/filedown.do?filepath=1000000757&fileName=L1750B-BF.pdf Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
I am also facing the same problem....
Plz suggest me the solution.. I have read all the related ansewers, but all the answers provided are useful only when computer is started and u r able to see something on the computer screen.. But my Screen is turning black and not showing any thing....
