SOURCE: rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
SOURCE: furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below. It should be simple to wire up. You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Ken
SOURCE: 4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
SOURCE: furuno le 6000 turns off imediatly after it is
probably receiving 10-11 volts, check for good power at the cable end where it plugs to the unit
SOURCE: furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
