Chaintech P35-121-16B9 need the manual or what jumper to switch from onboard video to the AGP slot.
Hi
Thank you for your query
Generally you dont need to disable the onboard VGA to AGP, all you need to do is to ensure that you plug the monitor lead into the AGP VGA card.
However if you wish to disable the onbaord VGA then please do the following
1) Ensure that the monitor lead is plugged into the onboard VGA card/port
2) Siwitch on PC then press F12, esc or del key to enter detup (When switching on there will be a message that says press X to enter setup)
3) This will present you with a blue BIOS screen, if yuo go through the menu there will be a option that says 'onboard/integrated peripherals'
4) choose that option and there will be a further option 'onboard VGA' this will be set to enabled. Set this to disabled and then save and exit
5) Note at this point you will have to move the VGA cable from the monitor from the back of the VGA prot to the AGP VGA card
I hope this has been helpful
Yyyyy
