Question about Precor EFX 546i Elliptical Version 4
Change batteries in consol of elliptical, but still the resistance or tension does not change or increase
Posted by phammel28 on
  • Anonymous Mar 13, 2014
    resistance does not change
John Mazmanian
    President:
  • Precor Master
  • 832 Answers
Their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
Posted on Mar 01, 2010
  • Paul Harries Jan 02, 2014
    Tried that with no effect
Just looking for ways to trouble shoot this to figure out if/why it's not working.
If you wish to get some details; check the site linked here. Pull up older posts. Check for treadmill articles.
http://electro-medical.blogspot.com/
May 17, 2016 | Nordic Track Nordictrack ELite 1300...
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
Resistance does not increase
please read the instruction and fix it. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.1_21_2013_5_29_53_pm.gif
Jan 20, 2013 | Schwinn 420 Elliptical Trainer
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
Reebok RL 1500 elliptical lost all resistance
I had the same exact problem, and I mean the EXACT same problem. I also changed out the battery with no change. I contacted the generator company thinking it might be that, but they told me it could be the control board. I ordered a control board, changed it out, and now it works like new.
To sum up: Get a new control board.
Jun 19, 2012 | Reebok RL1500 Elliptical
How do I fix my crosstrainer, magnetic resistance has stopped working
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Feb 15, 2012 | Exercise & Fitness
Why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Dec 06, 2011 | Exercise & Fitness
Precor EFX 546i Elliptical Version 4 Logo
674 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
Ngoro
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
