Vector 400 Watt Power Inverter #VEC024 Logo
Posted on Feb 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Output voltage unable to get above 90 V AC on battery tried on running car and only got 90 Volt AC also.
Gil Shultz
Level 3:
  • Master 3,464 Answers
  • Posted on Mar 01, 2010
Gil Shultz
Master
Level 3:
Answers
3464
Questions
Helped
730754
Points
11104
With the car voltage at 13.8V and you have less then a 400 Watt load the inverter is probably bad. The output voltage is not adjustable by the user.
Good Luck,
Gil
3answers
tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
Alternator is new.battery is new. GMC Yukon is not charging. What could the problem be.
Not sure but I believe the GMC Yukon has an in line fuse in the charging line. If so the output of the alternator will not get to the battery. One way to check is to measure the voltage, when the engine is running. At above idle it should be over 13 volts. Then measure the battery voltage, it should be almost the same within 200 to 400 mVolts. If not the charging line is open. Also if the alternator charging terminal is the same as the battery (12 to 12.7V) while the engine is running, that again indicates the alternator internal regulator is bad. If you turn on the headlights with the engine running above idle and the alternator output drops over a volt or so, the alternator is bad. This measurement can be taken at the battery plus terminal or the alternator charging output.
I have a stereo in my golf cart 48 Volt system If I push on the peddle to go the stereo shuts off when I let go it turns back on what could be the problem?
not knowing how or who installed the radio you could try the following
Is the radio 12volt ??, if so is it wired to one battery or running through a voltage reducer ??
if wired to one battery ( this is not advised as it should be wired through a voltage reducer) is the battery ok (load test battery)
If wired through a voltage reducer simulate driving then measure output voltage,, voltage should be equivalent to or slightly above accessory input voltage
1helpful
We have an Acculab V-200 electronic balance here at school. The AC adapter was misplaced, however one with a 12 volt output was found. It fits the balance but I am afraid to plug it in since the unit can...
re: Acculab V-200 Digital Scale
The original AC acpater is rated at 12VDC 300mA output. It is unregulated (i.e. the output voltage is about 16-17V with no load)
The centre pin is NEGATIVE, which is the opposite of "most" AC adapters.
(Acculab model number is 41-12-300D, for the 120V 60Hz version)
1helpful
2answers
My ups is switching on on battery for few seconds but without AC output, the same thing when I put AC power it switches on normally but also without AC output.What can I Do? Please help
does it have a led display for battery charge? if it is very low battery is bad,when you add a/c no output because bad battery will not provide a/c in power failure
I just purchased yesterday and found recall notice in upper tour pack. The battery was low charged over night and am going to check voltage and amps at battery while running today. What are the telltail...
With the battery fully charged, use a DVOM (digital volt ohm meter) to check the output of the charging system. Connect it across the battery, red meter lead to positive, black meter lead to negative. Put the meter's function switch in DC VOLTS, 20 VOLT range. Start the engine and bring it to a high idle of about 1500-2000 RPM. The meter should read 14.5 to 15.0 volts.
If the meter does not read correctly, unplug the regulator where it enters the front of the engine case. You'll be measuring the AC voltage at the engine case side of the plug. Put your meter's function switch in AC VOLTS, 50 VOLT range. Put one meter lead into one metal contact in the plug and the other lead into the other metal contact in the plug. Makes no difference which lead goes to which metal contact. Start the engine and bring it to a high idle. You should read 30 volts or better.
If you do not read 30 volts at the engine, your stator is bad. If you have 30 volts or more at the engine but low voltage at the battery, your regulator is probably bad. This is a simple test and it's accuracy is about 90% or so.
Good Luck
Steve
9helpful
2answers
1999 harley sportster will not charge the battery but, will run. however it will not keep running if you try to accelerate. i'm inclined to think it's the voltage regulator. but i'm not sure
To test the charging system, first you need a fully charged battery in the bike. With a fully charged battery, start the bike. Using a DVOM (digital volt ohm meter) put the red lead of the meter to the positive battery post and the black lead to the negative post. Put the meter in DC volts, 50 volt range. Bring the engine to a high idle and you should read between 14.5 and 15.0 volts at the battery. If you read this much, your charging system is operating as it should. If not, procede to check your alternator output.
If not, look for the connector that connects the alternator to the voltage regulator. Disconnect the connector. Now, going into the connector on the alternator side (the wire that comes from the left side engine case) test the output of the alternator. Put your meter in AC volts, 50 volt range. Notice we're measuring AC voltage now. Put one lead of the meter to each of the pins in the plug. Since it's AC voltage, it make no difference which lead goes where. Now start the engine and bring it to a high idle. You should read somewhere around 25 volts or higher. If you read this much voltage, your stator is good and your regulator may be bad. If not, your rotor is most likely bad.
One reason for a regulator not working correctly is lose of a good ground. Take the regulator off the frame and put a "star washer" (serated lock washer) between the regulator and the frame and tighten the mounting bolts. This will restore the ground on the regulator. If this doesn't help, the regulator is probably bad.
Good Luck
Steve
2answers
Can I test a 12v battery
My friend ... here is the answer:
Description:
  • WIGGLY VOLTAGE TESTER
  • Solenoid type tester polarity
  • indicator
  • 120/240/600 VAC; 50/60 HZ
  • Lifetime warranty
Your 12 volt battery is DC voltage as well as far below the voltage testing threshold of 120 volts.
Thank you for your interest n FixYa.com
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Top Vector Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
