Question about BenQ FP71G 17" LCD Monitor
Our computer screen will stay on for one second and then go black. Green button to signify it's on, is still showing, it simply goes black. What is happening and how can I fix it?
    New Friend:
  • 82 Answers
Sir if u really love your computer, then take it to the nearest dealer. The problem is might be with the capacitors.
But my suggestion hence, is to isolate the power board (the one that has the socket for the power input), check if any of the capacitors (the tall cylindrical structures) have bulging tops, if they do, try to replace them (Novices please bear the polarity in mind when you play with capacitors) with ones with higher rated ones (especially the voltage rating, normally these would be rated for 25 volts, so try getting one that is one step higher.
Posted on Feb 27, 2010
    Scholar:
  • 114 Answers
  1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable. Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
    Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.
  4. Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.
    Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.
    1. Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.
    2. If the new monitor you connected does not show anything either, proceed to Step 6.
    • If the new monitor you connected does show information from your computer, proceed to Step 7.
    1. Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.
    2. Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.
      Chances are your original monitor is working fine.
    3. Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.
      Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.
      Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8.
    4. Replace the monitor.
      WARNING: A computer monitor is not a user serviceable device. In other words - do not open the monitor and attempt to repair it yourself. If you would rather have your dead monitor serviced instead of replaced then please let a professional do it
    • Technicalwis Aug 21, 2011
      Hi Chaps more likely failed Parts in the Inverter circuit, (2SC5707,s) due to poor soldering on the inverter coils, this can sometimes blow the fuse as well, but you would not see it for one second if this was blown, Or it could be faulty backlight, these can be repalced but is a very long and tedious job. Cheers
    • Anonymous Sep 07, 2011
      The problem is likely to be the backlight - either the inverter is faulty (often the high-voltage capacitors in the output circuit) or the tubes have aged and their current draw dropped below the arbitrary minimum set in the inverter circuitry.
      The HV capacitors could be checked & replaced. If they are OK then either new tubes could be fitted, or the minimum current-limit disabled.
    When turned on, screen goes black, but power light stays green
    It sounds that the main digital board to this TV is faulty. Contact any service technician.
    Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
    Dell Computer Monitor - Black Screen
    If it worked on a computer at the IT person, it is most likely a faulty graphics card in your computer. You may want to get that checked out.
    Please vote if this helps.
    nLinked
    Computer Support Services
    Jun 08, 2009 | Dell E193FP 19" LCD Monitor
    Backlight for display cuts out
    Bad capacitors are a plague now, most likely cause of the black screen
    simply remove the doomed and caps that have color leaking from the top. and replace with duplicate good caps from your local electronics store
    Mar 22, 2009 | HP W2007 LCD Monitor
    Monitor comes on, I can see everything perfect then goes black
    "Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
    Jan 31, 2009 | Westinghouse L2046NV Monitor
    I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
    It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
    Dec 04, 2008 | Computers & Internet
    Westinghouse LCM22W2 shows a display then turns off after half a second
    I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
    Aug 13, 2008 | Westinghouse LCM-22w2 Television
    I have an HPW19 wide screen monitor that goes to black.
    I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
    May 26, 2008 | HP w19 19" LCD Monitor
    Faulty monitor
    This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
    May 11, 2007 | Proview XL370B (Black) 17 in. Flat Panel...
    Monitor goes dead AL1914
    Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
    What is VGA cable
    VGA Cables Adapters Converters and Devices C2G
    visit a computer mechanic for further trobleshooting
    Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
    BenQ FP71G 17" LCD Monitor Logo
    825 people viewed this question
    Top BenQ Computers & Internet Experts
    Ekse
    Joaquim Martins
    Karan Sethi
    Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
