Question about Amana Dehumidifiers
Need to replace a gas manifold for an Amana GCI 90A30 gas furnace. The part number, D6995003 is an obsolete Maytag part number since Goodman bought out Amana. I either need to find a source for the part or a part print to make the part. The orifice size is 43 and those are easy to come by. Please advise
Posted by chrispy493 on
taran_2005
  • 10,515 Answers
You could Purchase the Part from :-
http://www.apwagner.ca/index.php?main_page=product_info&products_id=486717&language=en
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 27, 2010
I have an amana d545m in the crawl space at my lakehome...when i went to check on the furnace filter, i noticed it was not running and has no power...how and what do i check to diagnose the...
First, make sure that there's power to the unit. Has a circuit breaker in the circuit breaker panel been tripped? If so, unplug the unit before resetting the breaker. Also, check the receptacle or extension cord that you're using to power the unit, as it may be damaged.
If you have power to the unit, it may be that some critter or insects have gotten into the unit and shouted it out. In which case, you're lucky that it didn't start a fire. It's not a good idea to leave the dehumidifier running unattended for a week or more.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Amana D545M Dehumidifier
I need to replace the part of my Maytag dehumidifier (Model # M7DH45B2A AR) that triggers the motor to work - it sits across the back or middle of the right hand bucket and has a sort of paddle on it I...
Here's a link to where you can find the "doohickey" your looking for. It's really called an activation switch. There's also an exploded view of the parts for your model. Also, if you can't find it for Maytag, try Fedders. They make the same unit and actually made the one you have with the Maytag brand name on it. The model numbers will be almost identical. Juts drop the 'M' off the front.
http://www.appliancefactoryparts.com/dehumidifiers/maytag/m7dh45b2a.html
Hope this helps with the part and the repair.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
I was looking for a manual to download, the fan is bad and I need a parts list. The download on the manual section did not work
Fedders made that unit for Maytag. Check the Fedders website for the same model number (just drop the M off the front of the model number) and you should be able to find what you need.
Apr 25, 2011 | Maytag M7DH45B2A Dehumidifier
Bought a Maytag 65 pint dehumidifier second hand. A hose or tray didn't come with it. Need to buy parts and would like to get a free owners manual. Model # M7DH65B2A*A Thank you, J Duke
You can find the manual and the parts online a Sears Parts Direct. However, when you enter the model number, drop the *A off the number.
FYI - This unit was made for Maytag by Fedders. And they make one of their own, with the same model number.
Hope this helps you.
Apr 01, 2011 | Maytag M3DH30B2A Dehumidifier
Where do you find replacement parts when they are discontinued? I need a regulator for my dehumidifer a7dh45b2.
Fedders also made identical dehumidifiers for Maytag. Their model numbers are almost identical, and their parts are the same. So, try finding the parts you need thru Maytag.
Mar 26, 2011 | Fedders A7DH45B2A Dehumidifier
Furnace/air cond. blower motor is smoking
I recently installed a horizontal gas furnace. All the electrical and gas supply was done correctly for sure, but upon the trial run, some smoke was coming out the supply lines into the house. I used some flex duct tape to seal all ductwork for air leaks. I also used some inside the first box coming off the heat exchangers to seal the inside of the box for leaks. Could the tape be burning because its to close to the heat exchangers and smoking or is it because its because its brand new and the heat exchanges have to burn a while? Please help
Jun 25, 2009 | Dehumidifiers
Dehumidifiers Logo
184 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
