Cisco Catalyst 4506-E Cat4500 E-series 6-slot Chassis Fan No PS WS-C4506-E Logo
Anonymous Posted on Feb 27, 2010
How to speed changed in gigabitEthernet 2/1 from cisco 4506switch
How to speed changed in gigabitEthernet 2/1 from cisco 4506 switch
  • Anonymous Mar 02, 2010
    i want to changed 100mbps (100 base fx ). i have access via console cable.
  • Anonymous May 11, 2010
    Hi Please can you dvise what speed you want to change to?, and do you have access to the switch either remotely or via console cable?
Anonymous
Level 3:
  • Master 561 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Answers
561
Questions
0
Helped
179126
Points
1723
Hi
Ok so once you have logged into the router you do the following
go into enable mode by tyoing in en
Then type in conf t
then type in int X where X = the interface
then type in speed 100
then type end
This will set the interface to 100mbps
Two routers, two WAN links
easy...
CODE
!R1
interface GigabitEthernet 0/0
ip address 172.16.1.1 255.255.255.252
ip ospf network point-to-point
bandwidth 100000 ! Makes OSPF think its 100Mbps
interface GigabitEthernet 0/1
ip address 172.16.2.1 255.255.255.252
bandwidth 10000 ! Makes OSPF think its 10Mbps
router ospf 10
network 172.16.1.1 0.0.0.0 area 0
network 172.16.2.1 0.0.0.0 area 0
network 10.1.1.1 0.0.0.0 area 0
passive-interface GigabitEthernet0/0/0
!R2
ip address 172.16.1.2 255.255.255.252
ip address 172.16.2.2 255.255.255.252
router ospf 10
network 172.16.1.2 0.0.0.0 area 0
network 172.16.2.2 0.0.0.0 area 0
network 10.1.2.1 0.0.0.0 area 0
This will make your wireless link preferred, if the link fails the OSPF adjacency will fail and routing will fallback to the other link.
You should ideally have some /32 loopback interfaces so the router will use this as the OSPF RID, or manually set the RID under the OSPF process.
More discussion about this you can see http://www.router-switch.com/forum/showTopicDetails/11/490
WS-X45-SUP6L-E Led is not coming to green
If you have two SUP's this one will be in standby mode.
Need to replace the Chassis of CISCO 4500 switch. Can i know Step by Step procedure to do this change.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/04replac.html.......................... please follow the above link
1helpful
I just replaced cisco 4506 with new 4506-e, the uplink port didn't work for trunking
Hi, if you installed a Supervisor 6L-E 10GE (X2) in the new 4506-E and you want to use the two 10GE uplinks as Gigabit, you need to type in the following config lines:
hw-module module 1 port-group 1 select gigabitethernet
hw-module module 1 port-group 2 select gigabitethernet
Hello, I tried the steps you have mentioned in the link below: http://www.fixya.com/support/t3932749-password_recovery_cisco_catalyst_4506 and the other similar resolutions on the cisco website but...
Please make sure you have only one supervisor module installed on your switch or else pull out the backup sup module and do this activity .
In the last step of reset it will ask to save the config.
do you wish to save this configuration? y/n [n]: y
You must reset or power cycle for new configuration to take effect
do not forget to type in y there.
2helpful
Password Recovery for Cisco Catalyst 4506
Please see Cisco's page at http://www.cisco.com/en/US/products/hw/routers/ps5199/products_password_recovery09186a0080093e12.shtml
for step by step details and more in depth instruction.
1. Reboot
2. Press the "break" button on your keyboard within 60 seconds of the power-up to put the router into ROMMON mode.
3. confreg 0x2142
4. reset
5. type, "no" when prompted to enter the initial configuration dialog.
6. enable
7. copy startup-config running-config
8. conf t
9. enable secret <password>
11. config-register 0x2102
12. reboot again
2answers
Problem with module WS-X4548-GB-RJ45V in Catalyst 4506
use software advisor in Cisco website to verify it.just follow the process.
console to it and show diag and see whether it detectable or not.
hope this help.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
