Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
It was working fine and then I went to turn it on
The digital book was working fine a couple of days ago and then I went to turn it on and it won't turn on. I have 2 western books of the same model and the power cord works with the other one... What can I do to get power to the external hard drive.....
Posted by phenisnoise on
Sphynkter
  • 221 Answers
If you're connecting a known-good power supply to the MyBook, and it's not turning on... I suspect that the MyBook has died. You should replace it or have it serviced. If the data on it is very important, it might be worth taking the drive apart and removing the hard drive inside and trying to recover data. If the data isn't important, I would say the MyBook is dead. Sorry.
Posted on Feb 27, 2010
96 GMC Yukon won't turn over
Thats what i would try and if that dont help, maybe check the connections at the starter.
Feb 18, 2013 | 1996 GMC Yukon
I have a vpc-E1500tp and it won't turn on and it won't charge... What do I do?
Lens is not all the way extended, so you can not turn it on. the defect maybe fixed buy pushing on the power button and pull the lens out gently by wiggling the lens? It may all be futile. Buy a new camera.
Mar 30, 2012 | Cameras
3 days ago, i went to work no problem,had to move it after 6-7 hrs of time, would not turn on 2 try's, started like normal on 3rd. 2 days ago i drove it locally a couple of times, no problems. today...
I ran into the problem and it was corrosion on the battery terminals. on the inside against the battery. also check the the terminals for good connection.
Stay warm
Dec 26, 2010 | GMC Sierra 1500 Cars & Trucks
The red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it...
he red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it has the same problem as before.
Feb 14, 2010 | Kodak CD43 Digital Camera
Mower ran fine a couple days ago. Went to start
Remove the plug, pull the rope several times. Wait about 30 minutes. Put the plug back in. Try again.
Choke off? Use sparingly if at all. If you have a primer button, only press it 5 or 6 times.
Is your plug in good contition? It may need a replacement. Make sure you get the correct plug.
Let me know how this works out.
a
Sep 21, 2009 | Garden
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
efs_perpends
efs_perpends
Mike
Michael Thomas
Michael Thomas
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
