Get the card out ..be sure it is no locked...and it is inserted in the proper way ..if it still says the same after this ..verify the card into a card reader to see if it is ok ..cause if it is damaged the camera will not see it .....If you just replaced this card and it is new ..be sure you format it in Fat 32 before using (can be done in computer or in the camera ) ..also be sure that the camera is supporting the size of the card if it is a new one and never used before in this camera ..
SOURCE: Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
SOURCE: my sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
i checked dat.but stil i says d same
Facing problem in doing so and not being able to know what to do next in a manner to resolve the problem. Just refer to the link given below which will definitely help you out in resolving your problem.
https://en.fotorettungsoftware.de/how-to...
