Question about KitchenAid Professional KFP770 Food Processor
I have a brand new food proccessor KFP770 the light comes on and it is assembled propley but doesnt work.
Posted by mareehall58 on
Adam Peake
  • 421 Answers
Is the bowl and lid locked into place correctly. The unit wont function if they aren't.
Posted on Feb 27, 2010
How to take out stuck chef bowl
I've not seen a bowl stuck on one of those unless the chopping blade is jammed on the shaft and preventing the bowl lifting up. Or is the chef bowl a smaller bowl that fits inside the main bowl?
Jan 12, 2016 | KitchenAid Professional KFP770 Food...
My kitchenaid 7cup new food processor will not work. There is no light that comes on. Help!
Brand new, take it back where you got it from then, no point fiddling about endangering your guarantee.
Oct 05, 2014 | KitchenAid Food Processors
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
My kitchenaid processor is not working
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Food proccessor jar damaged
yes ask the shopkeeper to give u used one
Jan 12, 2009 | Siemens MK-22201 Food Processor
I have a kitchenaid kfpw760 food processor. I assembled it as per manual then added ingredients to work bowl, but...my ingredients are below the blade in the bowl and the blade doesn't contact the...
The work bowl lid has a feed tube on it, and the unit should have also come with a "feed tube pusher," a plastic piece to help depress food through the feed tube itself.
With a food processor, you will want to assemble the unit first, engage, and then add ingredients. This will ensure the ingredients fall through the blade and/or disc to be processed thoroughly.
May 11, 2008 | KitchenAid Professional KFP770 Food...
Food Processor won't turn on?
Food processor housings MUST be assembled in a certain order. And each part usually clicks or snaps into place. When all parts are PROPERLY assembled, the safety interlock switch will engage. Until then, no workee.
Mar 05, 2008 | Food Processors
The disk stem is stuck
We had the same problem! I was bending a 18" pry bar and couldn't move it! Finally I tapped the spindle LIGHTLY and it broke loose and have had no more problems. I even bought $80 worth of replacement parts and did'nt use them. The serivce center sold me the parts but the Tech refused to talk me thru installing them.
Jan 03, 2008 | KitchenAid Professional KFP770 Food...
KitchenAid Professional KFP770 Food Processor Logo
192 people viewed this question
Top KitchenAid Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Zhareese
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
