Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco Vienna Superautomatica will not make a full cup of coffee
My Saeco Vienna Superautomatica will not make a full cup of coffee. Yes, the dial is turned to the far right for a full cup. We just had the unit serviced & I'm wondering if something was not adjusted. It made a full cup prior to service.
Posted by faborstein on
  • Anonymous Mar 22, 2014
    I have a Vienna superautomatica and it's working good but I can't figure out why when I put the dial to a full cup and only receive a 3/4 cup? Please help???
marsotdavid
    New Friend:
Have you got this answer ? I have the same issue
Posted on Aug 13, 2012
Anonymous
    New Friend:
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Posted on Apr 06, 2010
  • marsotdavid
    marsotdavid Aug 13, 2012
    Have you fixed this issue. I got the same problem.
Saeco Vienna Sup018 model. Changed flowmeter and sensor because of water flow problem. Now the unit makes one cup and red light comes on. Turn off machine to reset. Pump work fine, no clogs anywhere. Any...
hi
i had the same problem , you placed the chip with 3 legs on the wrong side turn it over and it will be ok .the writing on the chip of flow meter should face down.
Apr 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Plus Home Espresso Machine Superautomatic - right now,we like the machine. However, we cannot seem to get it to brew a decent cup of espresso. The first half is good and then goes to way too...
Grinder is only turn to a smaller # when its grinding. You can turn to a larger # any time. There is a dial on the panel that controls how much water goes through the brew unit.
What do your grinds look like. If they are like sugar granules your Ok, but if they are very coarse you grinder has come apart and needs to be cleaned and snaped back together. If you look at the white cork screw in the center of the grinder it should be centered and not to one side.
Nov 02, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Coffegrinder in Saeco does not work after cleaning out
Clean the chute to the brew unit. it may be time to get new burrs.
Aug 02, 2009 | Saeco Vienna SuperAutomatica Coffee...
Only half of a cup of coffee dispensed from Saeco Vienna
the trouble is the pipe that goes to the water tank follow it its hook to a white plastic sensor go in that piece and come out that the level sensor that broken that the first thing and most likely broken if not the circuit board
Apr 04, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
498 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
