First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
