Question about Orion VR0220 VCR
Vcr only plays sound, what's wrong ? - Orion VR0220 VCR
Posted by polarescape1 on
Grubhead
  • Orion Master
  • 5,700 Answers
Try cleaning the video head with Servisol Video 40 see image:
Posted on Feb 27, 2010
No sound when I play back a commercial DVD
May be something wrong with HDMi cable.
Is there sound when play VCR?
Please test - check with regular RCA cable AV out.
If OK. Next step Replace HDMI cable.
IF No sound with RCA cable look like need replace VCR Main Board.
Feb 20, 2015 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
Oct 15, 2012 | Sharp 13VT-N100 Combo
My sanyo 670 vcr player tape does not play,rewind or forward. It does just create some ratting sound and stops.
This sound like you have a tape stuck in the VCR. you should goto a Video engineer to get it taken out. And then check it out to see what is going wrong.
hope this helps
Apr 13, 2011 | Sanyo Televison & Video
Vcr sound but no picture
After checking the connection, played a pre-recorded tape and the picture was displayed gradually. After about 5 mins picture was completly restored. Lost of picture was due to dirty tape heads.
Mar 22, 2009 | Panasonic TH37PX60 37 in. Plasma...
Tv/vcr combo i hooked up a dvd player and cannot get sound
Usually you have to select video on the tv/vcr then play your dvd.
Jan 14, 2009 | Televison & Video
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
How do we get the vcr to play the picture it has sound but no picture
sounds like the heads are dirty on the vcr or you have in on the wrong setting for the video
Dec 06, 2008 | Televison & Video
Non-operating VCR
sounds like a parental lock...but not familiar if this model has that option
Jan 16, 2007 | Akai VS-J416EA VHS VCR
Televison & Video Logo
60 people viewed this question
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
