Computers & Internet Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a HP desktop PC and the DVD/CD ROM keeps opening and closing. How can I fix this? Thanks
electronic & computer repair& servicre
Level 3:
  • E-Machines Master 12,061 Answers
  • Posted on Feb 26, 2010
E-Machines Master
Level 3:
Answers
12061
Questions
0
Helped
4005338
Points
36390
It has gone faulty, this is not normal behavior. You will have to replace it. Check the button on the front, ensure it isn't jammed on?
My cd /dvd rom (dvd/cd burner) is hide..my pc doesnt recognize it..help please..i dont know if i lost a driver
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Pc trabalsuting
if you are referring to troubleshooting your cd rom
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
My hp d330 desktop will not read any discs it will open and close but thats it, what can i do to fix this problem
Well first of all depending on the type of media you are using can be a problem. If you are trying to read a DVD and you only have a CD reader that would be a problem. Now if it wont read any. You will need to replace it with a new cd/dvd rom.
Hp xw8400 drive door wont open after it reads a
Straighten a paper clip and push it inside the small hole just above the open/close button while you press the button. You'll need to apply some force. This is usually caused when the gear inside the cd/dvd rom is not working properly or damaged. Good luck. Thanks for using FixYa.
2answers
Cd rom
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
Cd/dvd door is opening and closeing all by it self
this is due to improper connection of wire from optical drive to motherboard i.e check whether the power cable/ide(sata)cable is not loose.Also clean their plugging area.problem will be solved.thanks.
I am trying to create recovery disc I can,t load them on the dvd, it keeps saying the dvd has something on it already, which I know isn't the case. Anothr problem I have is that when I use the computer...
the error you are seeing is because a piece of your software such as internet explorer has been corrupted or deleted the cd rom your pc is asking for is a system resore disc. find yourself an xp disc if that is the os you are using and do a repair that should fix your issue
2answers
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
