I recently bought a Motorola V3I that is unlocked, whenever I change the ring tone settings they dont stay. It say on the phone that the desired ring tone I chose is there, however on recieving a call, the default ring tone comes up, how can I change this?
Go onto the music download and click on it then before playing it look at the options they'll either be "set as" or settings. Go on settings or set as and set it as ring tone.
If this doesn't work or them options don't appear go onto your main menu and go on either settings or if your phone has one a ring tone setting. Then go onto sound settings. Then click on it and on there should be your downloaded music
NOTE: Make sure it's on your phone not stored on your memory card.
Hope I helped
Dr Reed
Your phone’s four-digit lock/unlock code is originally set to 1234. The six-digit security code is originally set to 000000.
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn’t work, press and enter your six-digit security code instead. .
hi there , you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps.. Simon
did the tones come pre installed on the phone? why dont you try using mp3 ring tones? download mp3 songs on your phone, then you can set them as ring tones. they work much beter than ordinary ring tones
go to options ring styles... then for example your ring style is loud, then go to loud detail and there select the type of alert for messages. similarly it applies for all the other ring styles.
Your outter speaker is damaged - you got to love ebay!
Contact your seller and request a replacement or refund because it will cost you upto $50 to fix it
