No diagram available, but I should be able to walk you through the process easy enough. First, make sure your water is off and you have relieved the existing pressure by opening a nearby faucet until the water stops running. Then remove the handle. Under the handle there will be a nut that can be removed with an adjustable crescent wrench or water pump pliers (if you use the pliers be careful not to mar the surface.) Make note of which way the stopper for the handle is sitting, this is the raised piece of plastic on top of the stem. Then after the nut is removed, you can use some pliers to grab the center of the stem and pull straight out. Once the stem is out, inside the faucet you will see the seat (the rubber piece) sitting down in a little hole and under that a spring. These two pieces are typically the culprit for the leaking faucet so make sure you replace these as well or the faucet will continue leaking. Then working in reverse order, put the new items back in place and then before tightening the handle in place, turn the water back on and check for leaks at the handle as well as the spout. If you have any leaks, tighten the nut at the handle if that is what is leaking, or turn off the water and start the process again to reposition the seat and spring. Good luck, you can do it.
There is definitely a problem with the cold valve if it is leaking, but it seems odd that it doesn't leak when it is on. If I was doing this, I would replace both valves.
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
this sounds like the ballvalve needs replacing & the hissing is the sound of water as the valve is not shutting off properly.
The valve at the bottom of the tank is possibly just a half turn valve so try that & see if it stops the water.
The water leaking could be thatthe water level is too high & leaking around the handle assembly & running down, so it kinda looks as though its leaking below?
The handle assembly may of come adrift so thats whay the handle may look loose ?
Solution sounds quite straight forward, a new ballvalve assembly needs to be fitted & the handle assembly sorting.
The leak will be rectified when you replace the old ballvalve, as you will need to turn off the water to the unit to remove the ballvalve, whilst the water is off a service valve should be fitted so as any future probs or servicing needs doing then it can be isolated without the need for turning the whole house off?
This work should be carried out by a registered plumber & is as i said a straight forward job.Price approx £65.00 subject to a survey by the plumber.
