Watches Logo
Anonymous Posted on Feb 26, 2010
Can someone tell me how to work the 3 dials on a Tourneau Safari Sea Big Date watch? I ordered the watch and it did not come with a manual (I am getting ready to call up Tourneau to ask them to mail me one).
  • Anonymous Feb 26, 2010
    Here goes. The watch can be found at the below URL. I don't know how to work the 3 buttons on the side.
    http://www.tourneau.com/Tourneau/Main/Ca...
    Make: Tourneau
    Bezel Function: Rotatable, shows elapsed time
    Bezel Material: Stainless Steel
    Bracelet / Strap: Stainless steel bracelet
    Case: Stainless steel
    Case Back: ComfortCurved steel
    Case Diameter: 42 mm
    Clasp Type: Stainless steel deployant
    Complications: Chronograph, date
    Crystal: Sapphire
    Dial Color: Silver
    Movement: Quartz
    Series: Safari
    Style Type: Sport
    Water Resistant: 10 ATM
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    Tourneau is just a dealer, not the producer. Give us : make, model, all the writings on case back, type of movement.
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 27, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813896
Points
13579
The push button at 2 o'clock is START/STOP/RESTART button for chronograph function. Push button at 4 is for RESET (it resets chronograph hand to zero when pushed). Crown at 3 is for time and date setting. When pulled out to first click, it changes the dates by the means of turning it. When pulled out to the second click, it sets the time by turning it.
1helpful
Hi, I'm currently in Melbourne, Australia and I am trying to correct the time on my my Seiko watch however am struggling big time. to that point.
http://www.seiko.co.uk/customer-support/support/instruction-booklets
the date might be out as the time might be out by 12 hours .
model is on back of watch put it in the above web site link and get an instruction manual
Good luck !
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 • Watches
Can someone tell me how to set date month and day on an attention manual watch
A manual watch is set by pulling out the winder.
Those with a date have three positions:-
1 normal operation
3 fully out - used to set the time
2 half way between 1 & 3 which is used to set the date and day. In this position turn it one way to set the day and the other way to set the date.
Return the winder to position 1 after setting.
Jun 04, 2011 • Watches
Why is date on my mondaine 94145 watch 38
Date setting should be described in your manual but if you do not have it, then you can get another copy by going to their web site "modaine.com".
Select "after sales service" and a list of instructions appear. This list claims to cover all the watches they make but doesn't include the model number you quoted. Could it be that the number was the serial number for the watch?
The manual list is not too long, so it should be possible to down load the most likely looking candidates.
1helpful
How do you set the date so it changes at midnight on my tourneau
Go to the Tourneau web site (tourneau.com)
Find your watch.
On the "details" page for your watch there is a box "Ask our experts a question".
At the price of these watches you should receive an excellent service!
Jan 04, 2010 • Watches
4helpful
2answers
Is this cartier watch authentic
Nobody can tell you this by the number only exept Cartier itself.
Follow this link, enter details and ask questions directly to Cartier:
http://www.cartier.com/en_na/Cartier
Rate me, please.
7helpful
Problem with casio sea-pathfinder watch
For all Casio watches go to www.casio.com select "Support" then "Manuals" then "Watches".
You will then be able to enter the 4 digit number in the square box to get the manual for your watch or module inside is actually what the instructions refer to.
The problem of changing functions automatically is called "Auto Display" and can be stopped and started in Sea-Pathfinder SPF-40 (modue 2273) by pressing the bottom left button for 3 seconds.
16helpful
2answers
Adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
1helpful
Trouble with Fossil ME1014
I looked at a picture of the watch. I see the date. the dial that is right below the hands is a moon dial which does the phases of the moon & below that you have a separate second hand. A lot of times on a watch that looks like that if you pull the crown where you set the watch with out half a click it will set the date if you turn it on way and the moon dial if you turn it the other way. To set the moon dial on the watch you need to put it on the full moon when the moon is full again then it will keep up with the phases of the moon. I hope this helps.
Mar 09, 2008 • Watches
Watch stops intermittently.
Make sure the dial that is used to set your watch is snug against the frame of the watch. Sometimes when people reset the time on their watches they don't push the dial all the way back in which will cause it to stop. If it is an intermitten problem it may be close but not all the way in. Some watches continue to run when they are being set; whereas, some stop when the dial is pulled to reset them.
Top Bell Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Bell Watch Expert? Answer questions, earn points and help others
