Hobart AM14-253 Free-standing Dishwasher Logo
Anonymous Posted on Feb 26, 2010
My am-14 is eating the detergent. It use to last a month now less than one week. Is there a soleniod valve thatisn't closing?
GPEC
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 26, 2010
GPEC
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3068
Points
29
The over consumption of detergent could be caused by a couple of things. If the detergent is dispensed by an external chemical pump, the detergent probe may not be working correctly. The probe will cause the pump to dispense too much chemical if it is dirty or has hard water build up on it. You can check the probe and clean it of any debris. The probe is located in the bottom of the wash tank. Most chemical suppliers take care of these sorts of issues at no cost to the customer. If your rinse solenoid is not closing properly, this could cause the detergent to flow down the standpipe (overflow drain). This would make the chemical pump dispense detergent more often then usual. An easy way to check if your rinse soleniod is stuck open is to look at your rinse arms if water is flowing out of them and doesn't stop this would mean your solenoid is in need of repair.
Kind Regards
1helpful
After the cycle completes, the bleach, softener, and detergent trays are filled with water.
The dispenser for the bleach is clogged up. You can pull the tray out of the washer and take it to a sink. There will be round circular siphon towers there and you will need to clean them and under the trays there are also the same towers and clean those. Reassemble and holding the complete tray as level as you can slowly run water into the bleach dispenser cup until it starts siphoning out.
Detergent dispenser not closing
split the door inner from the outer - screws round the periphery. you will need a multimeter check if there is a supply to the detergent dispenser when there should not be ie during rinse and hold program or before starting the cycle. if there is a supply then the module is faulty. if not then fault probably lies with the dispenser itself. having split the door you can see how to remove. there are two methods of fixing. most common is six screws holding clamps. some are a push and click fit
Find how long you can keep food in the freezer after you have bought it?
Most things can last several weeks. Many foods do just fine for several months. But all foods start to lose flavor. In particular, prepared products like, say, chicken nuggets or French fries, things high in oil content and lower in water content, will stay tasting the same longer. As will most meat. But there are many exceptions. For example, frozen concentrated juice and chicken broth should last quite a while, like six months or much longer. Don't worry about it; as the weeks go by, just try to be a good home economist and choose to eat older items from the freezer first rather than exactly what you might want to eat for a particular meal.
Is it true that some reptiles can go a month without eating?
Some reptiles, particularly crocodiles and boa constrictors, can go for extended periods of fasting (some may last up to 6 weeks). Pythons can go a month without food after eating a rabbit.
Aug 14, 2012 • Reptile
I have a 07 predator 500 that is eating valve shims? I have had it @ the dealer 4 months ago and has done it again. The dealer said it would work or it would happen again in a week or month or a ye
Ensure that your exhaust system is standard - low back-pressure can burn valves out & leave deposits on valvesEnsure the correct plug is in useUse good quality fuel with a lead substitute or octane booster - valve seat pitting occurs without
Why do you have to use H.E. detergent in front load washers?
not as much suds as regular detergent and double the strenth,front load washers use less water than top loaders,if you use to much detergent the machine will keep filling and draining to try to get the suds out.also you should only be using 1/4 cup of H.E. detergent or you can damage the spider gear in the washer,you'll know if it breaks you'll hear the tub banging all around loudly when it's in final spin,the spider gear is made out of soft metal and the extra detergent eats at the metal
DONT KNOW EXACTLY WHAT IS WRONG. OUR POWER BILL LAST YEAR WAS 211.00 AND KNOW WITH THISE BILL IS 678.00. IT IS H EATING AN 18X23 ROOM. THE SETTING FOR TEMP. IS ON 72 DEGREES. THIS THING HAS RUN OUR BILL UP...
Simple way to pay less bill with big comfort.
Tips for it: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Clean indoor and out door periodically ( Once in 4 months) Clean Air filter every fortnightly. Avoid frequent opening of the door where it's air conditioned. Avoid keep closing the doors even a/c is switch off. It helps to cool the room next times in short minutes. Use proper breaker, wiring for your air conditioner plug points. Make sure your elect meter is working properly.Check your Elect meter with 1000watts bulb for one hour. It should consume one unit only. Hope, it's helpful.
2helpful
High tick over
Try replacing the air mass meter
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
