Question about U.S. Robotics Computers & Internet
Good morning Sir, I have the cordless phone US Robotics 9630 "Skype phone". The problem is that the speakerphone does not work if the telephone is away from the SET and it shuts the phone off when using it. Please advise. Regards. My email address is: [email protected] George Sayah
Posted by gnsayah on
5 Related Answers
Anonymous
SOURCE: Help with 4-line phones
i can answer the phone but cannot talk on the recv. it works the same on speaker as well. you can hear but they cannot hear me. i have changed out the headset, but its still the same. any help would be greatly appreciated.
Posted on Sep 16, 2008
Anonymous
SOURCE: The phone can not sign in
I had excatly the same problems and therefore I called the Dualphone hotline. A very helpful person send me this code, which I used and after 2 days with many frustrations this solved all problems within 30 minutes:
"Dear Sir, madam,
Thank you for contacting dual phone Support.
"Press menu followed by 1 – 3 – 9 – 7 – 5. You will prompt to one pageFWU configuration and select Beta firmware. Install the 0247 beta firmware."
Best regards,
Dualphone support"
Hope it can someone
Stein
Posted on Mar 23, 2009
toac990
Mohd. Tareq
  • 838 Answers
SOURCE: I cant sign in to my yahoo mail service this
[email protected]: is this the ID you forgot the password... no problem click here
Reset your password from this site by your alternate email(hotmail) address (**********@h******.c**.au)
please follow the screenshot... member= your hotmail login ID
Posted on Oct 29, 2009
Anonymous
SOURCE: rca 25202RE3-B
Adding numbers into speed dial is a little weird. You press "store" then enter the number, then press "store" again and then press the speed dial button you wish to save it to, and the screen should say "ok" after you are all done.
Posted on Jan 26, 2010
Amado Petallana
  • 320 Answers
SOURCE: I HAVE SAMSUNG GT S5620 TELEPHONE, HOW CAN I LOAD
To load up your phone with skype and other telephone programs, you have to access the skype website and click download skype to mobile phone by entering your phone number and click send to my phone. Skype will send download link to your phone.
Posted on Nov 30, 2010
Instruction manual for RCA visys 6.0
Good morning,
How do I retrieve voicemail messages on this system?
Sep 08, 2014 | RCA ViSYS 25255RE2 2-Line DECT 6.0 Digital...
Why doesn't the LCD display doesn't work?
Does the LCD not work at all? or do you mean that it doesn't display Caller ID information? If the LCD is completely dead, you'll need to get the phone repaired. On the other hand, if it's just the Caller ID that's on the fritz, try this: unplug the base from the power socket; remove any batteries in both the base and the handset; wait one minute; plug the base back into the wall and replace all batteries. This will reset the Caller ID so it works again. (Depending on the phone you may or may not lose settings and memorized numbers.) If this doesn't help, the problem will require a professional repair.
Aug 06, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
I HAVE SAMSUNG GT S5620 TELEPHONE, HOW CAN I LOAD IN MY TELEPHONE, SKYPE, NIMBUZZ AND VOIP TELEPHONE PROGRAM? IF YOU HELP ME I WILL BE VERY VERY HAPPY DEAR SIR. MY E-MAIL ADDRESS :...
Nov 30, 2010 | Samsung S5620 Cell Phone
When i dial and press the talk butto, i still hear a dial tone...please help
Please follow these troubleshooting steps;
Tip 1 of 9
Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
Tip 2 of 9
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Tip 3 of 9
Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Tip 4 of 9
To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
Tip 5 of 9
Excessive background noise will cause a speakerphone to fade in and out. Try controlling the background noise by turning off any audio devices near the speakerphone. Also, try to avoid interrupting the person at the other end of the conversation while they are speaking. If background noise cannot be controlled, you should terminate speakerphone operation and return to normal handset mode.
Tip 6 of 9
Disconnect any other equipment that is connected in series with your phone. If you phone begins to perform normally, there is a compatability issue with your other equipment.
Tip 7 of 9
If your phone shares a power outlet with a modem, or if it is plugged in to a shared surge protector, try plugging the phone (or modem/surge protector) in at a different location. If this solves the problem, re-locate your phone or modem farther apart from one another, or use separate surge protectors.
Tip 8 of 9
There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. This is normal radio operation.
Tip 9 of 9
You may have a line problem. To test for a line problem, test your unit at another location such as your neighbor’s or relative’s house. If your unit works at another location, contact your local telephone company
May 01, 2008 | Vtech Cordless 6041 Phone
Skype Dual Phone RTX 3045
try the latest driver at:
http://dualphone.net/Get_software-42.aspx
Jan 13, 2008 | SKYPE RTX Cordless DUALphone VOIP...
Computers & Internet Logo
142 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Steven Wander
Steven Wander
Lee Hodgson
Lee Hodgson
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
