Question about GE 26920 Cordless Phone
GE 26920GE2-R cordless phone always rests on charger yet when I use it after a couple minutes there is a loud annoying beep, and then it will just die. Can't find our manual. Thanks
Posted by patandtom784 on
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: GE phone parts
Bring the phone into your local radioshack store, they sell a variety of adapters. They can match up the voltage, amperage, and plug end based on the specs of the phone, just bring it in. Good Luck
Posted on Sep 14, 2007
Anonymous
SOURCE: Lost manual for the GE DECT 6.0 Cordless Digital Phone # 28115FE1
http://www.home-electronics.net/ge/pc/IB/28115FE1_IB.pdf
GE phones are distributed by Thomson Electronics...the manuals are available at:
www.hom-electronics.net
Posted on Sep 02, 2008
kellybode
SOURCE: Seeking a manual for GE Cordless Phone, Model #25942GE2-A
Go to www.GE.com/phones. You can download manuals there or call 800-448-0329. There is an option to get manuals.
Posted on Dec 03, 2008
rcjkar
Richard Jones
SOURCE: phone charging indicator light
register phone instuction
Posted on Dec 05, 2008
Anonymous
SOURCE: Need Instruction manual for GE cordless phone model# 28021ee1A
need manual for cordles phone model no. 27928GE2-A
Posted on May 14, 2009
Phone has beep & no dial tone. Screen says its searching
I was unable to locate a manual for your phone online, but can offer some suggestions to solve your problem.
Most cordless phones beep in battery low, out of range, and other situations. Since it is also displaying the "Searching" message, it indicates that it lost its link with the base due to being brought too far from it or the battery power has fallen to low to permit use as far as it may have worked before.
The quick fix is to simply place the phone into the base / charger. This re-establishes a security link between the cordless handset and your telephone line. This is a safeguard that is used to prevent others with the same cordless phone from merely getting "near your base / charger" and gaining access to your dial tone to place calls on your phone line.
If the battery is low, it should left to remain on the base / charger long enough to fully charge the battery. If the battery fails to charge, there may be an issue with the base / charger; but it is much more likely to be a problem with a battery that has reached the end of its useful life (batteries seldom last more than a couple of years and may not last a single year depending on usage). Either condition will require replacement of the faulty device before using again.
If you need more help, you may want to try Thompson Electronics (if purchased prior to 2011) at 800-448-0329 or their website; as it appears GE contracts with them for support after the warranty period.
Mar 30, 2012 | GE 27990GE3 Cordless Phone
Ge 6.0 model #28112ee3-a
Most likely the battery is done being a battery.
and will not hold a charge.
Goto the store (wal-mart) and purchase a new battery witch should be about $10.
Selvol
Mar 02, 2012 | Uniden Cordless Phone
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
How to Silence the Key Pad
I called GE directly and they said there was no option to silence the key pad on this phone. (I think I'll return it).
Sep 11, 2009 | Uniden Cordless Phone
Hi, I have two GE 2.4 ghz cordless phones in my home. The base of the charger always has a blinking red light. That phone doesn't hold a charge very long. It it the battery or the charger? I emailed GE and...
batterys don't normally last long as constant charge with short breaks are bad for them. i'd bet the battery. does that happen with both phones?
\put a multimeter to the pins on the charger. my tongue tests 9 volt batterys
Jun 09, 2009 | Uniden Cordless Phone
Uniden Dect 6.0, the base keeps beeping
You have your answering machine set up to beep when you get a new message. Go through the menu for setting up the answering machine and turn that feature off.
Apr 12, 2009 | Uniden 5.8GHz Dual Cordless Phone
MA355 Cordless Phone Makes Noise when IN CHARGER?
yes this happens to me also. I haven't tried anything to fix it but it is darn annoying.
Apr 26, 2008 | Uniden Cordless Phone
How is ringer volume adjusted?
the ringer is too loud and the beeps from pressing the buttons are too loud.
Dec 30, 2007 | GE 25932 Cordless Phone
Buttons to loud!
Read the Manual, it should be there.
Nov 18, 2007 | GE 25953 Cordless Phone
PHONE KEEPS BEEPING WHILE RECHARGING
make sure your plug in is all the way inserted into your phone. If it is not completely in your plug-in, then it will make a beeping noise as it connects and disconnects from your phone. ALSO just common sense here, make sure its not just messages coming through.
Oct 14, 2007 | Samsung UpStage SPH-m620 Cellular Phone
GE 26920 Cordless Phone Logo
146 people viewed this question
Top GE Lands Phones Experts
Bruce Robin
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
