Marshall MG250dfx
The overdrive sound drops out when I am playing, I need to switch back to clean sound and play very hard to get the sound back. Anyone have this issues?
I have read that the problem is in the FX send/return jacks which oxidize if not used much. All you have to do, apparently, is ram a jack plug in and out a bunch of times. This breaks up the oxidation, and allows the amp to work properly again.
Its a mystery. took mine to a very reputable amp tech and he was baffled. Also couldn't get it to happen in front of him either which really makes things difficult.they took it apart cleaned it up, resoldered any questionable solder joints, lubed and cleaned the fan. result. 3 months later it started happening again. Good luck
I have no solution, but I have the exact same problem with a 250dfx. Volumn returns only occassionally. I can plug into FX Return and get volumn. Aggravating.
How to replace transponder on marshall mg250dfx
