Question about GE 30 in. JGP337 Gas Cooktop
Igniter clicking I have a GE stove model: jgp337, when i turn on the stove the igniter continues to click even whent he stove lites, I have to cut power to stop the igniter from sparking - Help
Posted by tn6fshn on
3 Related Answers
Anonymous
  • 59 Answers
SOURCE: Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Posted on Jan 11, 2009
Joe Hogan
  • 10865 Answers
SOURCE: ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Posted on Jul 24, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: One ignitor on my GE jgp337 clicks once every
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
How do I replace the jgp636 igniter switch?
How do I lite a whirlpool electric gas stove?
Dec 31, 2012 | GE Profile JGP636 Gas Cooktop
My GE Monogram Gas Cooktop model ZGU650N4DH5SS ignitor keeps sparking even after the stove is lite. What do I need to change or fix please?
Hi Ishiggs,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Cooktops
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Aug 15, 2010 | GE 30 in. JGP337 Gas Cooktop
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
One ignitor on my GE jgp337 clicks once every couple of minutes continuously. What can I do?
heatman101
Jun 05, 2010 | GE 30 in. JGP337 Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Gas burner will not completely lite
Call GE answer center 1-800-626-2000 aek for tech help. Have you Model # off your data plate ready.
May 09, 2009 | GE 30 in. JGP337 Gas Cooktop
Hi
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
186 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
