Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panasonic panafax UF 885 does not print communications journal after each communication. Made change according to manual, but change does not stick.
    New Friend:
  • 54 Answers
Menu#004 set ok
Posted on Feb 27, 2010
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Can i re-print the document form the memory of the fax machine?
no, you can only print out a journal to show what fax number it came from.
Aug 03, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 resets itself when trying to print comm journal
sounds like your firmware might be shot and it needs to be reinstalled, if your in canada i can recomend a tech
Nov 03, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Hi, at the moment my panafax UF-770 is printing a report for every transmission. I want to stop that, so that it only prints a report if the fax did not go through and the monthly or so report. I cannot...
To change the communications journal settings:
Press:
Function
7
Set
12
Set
1= off
2=always
3= incomplete only
Once you have chosen 1,2, or 3, hit Set
Hit STOP to exit programming mode.
This model only stores the last 100 transactions (sent or received faxes).
To print the last 100 transactions:
Press:
Function
6
Set
The machine will return to an idle / ready state when printing has completed.
Apr 07, 2008 | Office Equipment & Supplies
No. If this is needed, make sure to turn on automatic reports
May 01, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
199 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
