Range control panel started smoking, I checked it out and found control panel had burnt out. I changed the panel, now clock continually flashing.
And F5 01 displays everytime you try to switch on a ring.
Paperwork suggests break between power board and UIB.
What do I check to find out what part is at fault?
Kenmore elite 790.9912
SOURCE: Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
SOURCE: kenmore stove elite 790
**E-1,and F-5**
Some of the codes in the clock where programed backwards....some may show E-1,and F-5 and some may show F5 - E1.
F5 - E0 F5 - E1 and E2
Check door/latch switch
Replace switch if defective
OR
F5,6,7
EOC failure
Replace EOC
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
SOURCE: control panel on my Kenmore range smoked
Make sure there is only 120vac on the white and black wires. You do not want to burn up a new control. Unless you already know why it fried...
Eric
SOURCE: I have an error message and cannot get it to
I have the same problem, if you figure it out please post it.
