Question about Uniden BC350C Base Scanner
NEED FREQUENCYS IN WASH. COUNTY ARK..???
In need of frequencys for Washington County Ark..
Posted by carolkiely on
JOHN BABA
    Genius:
  • 1,274 Answers
Try RadioFreq.com....hope this helps
Posted on Mar 01, 2010
I would like to know if there is away I can print out the frequencies & channels for Monterey, Calif Thank You
Yes, go for it :>)
  • Monterey County, California (CA) Scanner Frequencies and ... www.radioreference.com > US > California Scanner Frequencies and Radio Frequency Reference for Monterey County, ... Monterey County California . ... Monterey Regional Waste Management District : FM :
  • N6SPD : MONTEREY PENINSULA POLICE FREQUENCIES n6spd.com/freq/mcfreq.htm 155 rows · CHANNEL # FREQUENCY: TONE: SHERIFF: North Dispatch: 1: 159.090: ...
    • AGENCY TYPE CHANNEL # FREQUENCY SHERIFF North Dispatch 1 159.090 CAL FIRE North Dispatch Command 1 152.720
  • Monterey County Scanner Frequencies (CA) - Intercept interceptradio.com/slocal.php?disp=1&country=US&state=CA&county=... 39 rows · Home of the world's largest radio/scanner frequency database ...
    • Freq PL/M City Call 51.76 114.8 Monterey WE6R 51.82 136.5 San Ardo WR6VHF
  • Monterey Park Scanner Frequencies (Los Angeles County CA) www.interceptradio.com/slocal.php?disp=1&country=US&state=CA&county... Scanner Frequencies for Monterey Park Los Angeles county CA US. ... Los Angeles County Scanner Frequencies (CA) ... Channel Notes;
  • View and Compare Your Scanner Options ' Police Scanners www.policescanners.net/scanners-ca-monterey View and Compare Your Scanner ... About Us; View and Compare Your Scanner Options Monterey County, California Fire Police ... Fire and EMS channels in ...
  • California: Monterey - Radio Scanner Frequencies www.scannerfrequencies.com/radio/california/monterey/page/2 Scanner Frequencies ... USA CA Monterey. Articles Contact Submit. Follow @ScannerFreqs. California: Monterey. Frequency: CallSign: DBA/Licensee: City:
  • California Public Safety Frequencies - Bay-Net www.bay-net.org/frequency_calif.html 866.2000 - Channels 20 & 21 - Northern California. ... to air tactical frequencies. In southern California FIRESCOPE area ... California Public Safety Frequency ...
  • Monterey Park, California - Scanner Frequencies - Phone ... www.cityfreq.com/ca/montereypark Scanner frequencies, phone numbers, ... Monterey Park, California Scanner Frequencies. Public Safety. AHMC MONTEREY PARK HOSPITAL (CARMEN ...
  • FCC Licenses and Scanner Frequencies for Monterey County ... www.radioreference.com > US > California > Monterey (County) FCC Licenses and Scanner Frequency Listing for Monterey County, California ... US > California > Monterey (County) County Home;
  • Monterey County Frequencies - Scanning California www.scancal.org/old/monterey/county.html Monterey County Napa County ... Scanning Central & Northern California Frequencies Monterey County Last Updated: ... Channel 2 - Secondary
  • Feb 04, 2016 | Radio Communications
    Police frequency in your city
    For the most complete database of frequencies for radio scanners visit the Radio Reference Database and website. Not only will you find a database for all 50 states but there are forums for each state, and selected live audio feeds. It is a great website/reference.
    The Radio Reference Database United States
    May 01, 2014 | Radio Communications
    Need code for columbia co. ga 30907
    1. Type in this URL address-http://www.nws.noaa.gov/nwr/indexnw.htm.
    2. Click on your state
    3. Find the county you live in. The S.A.M.E. code should be listed in the "SAME#" column. If you have two codes for your county, it probably means one of the codes transmits for different regions of your county. No problem, all you have to do is check your frequency station. Whatever frequency receives the best reception for your county (for example 162.450), put in the S.A.M.E code for the county that has that frequency.
    Aug 18, 2010 | Midland WR-100 Weather/RDS Radio
    Need code for washington county
    3. Find the county you live in. The S.A.M.E. code should be listed in the "SAME#" column. If you have two codes for your county, it probably means you have more than one frequency channel for your county. No problem, all you have to do is check the frequency channels for your county. Whatever frequency receives the best reception for your region (for example 162.450), try that on the radio along with punching in its S.A.M.E code.
    Aug 13, 2010 | Midland WR-100 Weather/RDS Radio
    I need help programming my Pro 97 to listen to fire/police channels in Kitsap County washington
    Press manual,enter channel number,then press manual,enter the frequency you want including the decimal point,then press E,if you make a mistake press CLR twice to erase. You can get the frequency,s you want at RadioFreq.com ...hope this helps...
    Mar 16, 2010 | Radio Shack Pro-97 Handheld Scanner
    Need Frequencys For Wash. County Ark..??
    For a comprehensive database of active frequencies in your area, visit:
    www.RadioReference.com
    Bill B
    Feb 25, 2010 | Uniden BC350C Base Scanner
    The Problem Is, None Of My Frequencys Work from the starter guide. do i need more frequencys
    if it has a wx or weather button press that to see if the scanner is working ok, if you get the weather radio ok then you can get your local freqencies at www.radioreference.com click database, then your state, then your county and a list will come up of your local frequencies.
    Mar 19, 2009 | Uniden BC60XLT-1 Handheld Scanner
    Radio shack hand held scanner Cat. no. 20-315
    L live in Haywood county NC and I am running the following Radioshack scanners: Pro82, Pro95 and a Pro97. When will the rebanding take these scanners down. Also will the Pro97 beable to be rebanded as it really is a good scanner.
    Nov 10, 2007 | Radio Shack Pro-97 Handheld Scanner
    Uniden BC350C Base Scanner Logo
    64 people viewed this question
    Top Uniden Radio Communications Experts
    Robert McClure
    eradiostore
    eradiostore
    Marvin
    Marvin
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
