Question about Dell Dimension 3000 PC Desktop
Dell dimension 3010 wont start up it just has a blinking amber power light, and nothing powers up, eg fans, harddrive etc.
Posted by itassistant on
Anonymous
  • 32 Answers
Hello there....
Looks like you have some power issue.
Please check you PC power supply unit if it generate enough power for the PC or another possibility is that you got faulty Motherboard.
But, based on my experience its around 80% power issue.
Hope this helps... :D
Posted on Apr 14, 2010
Anonymous
    New Friend:
Dell gx 280 system halted my pc
Posted on Feb 25, 2010
Dell Desktop Fan Runs all the time and Amber Light
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
Dell Ispirim will not boot after power failure. Fans run, mb light on. Dtartup buttom amber.
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Dell dimension 8200 help
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
1helpful
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
4helpful
3answers
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
2helpful
By dell dimension4300 power switch is just blinking amber and wil
1helpful
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Thank You.
Dell Dimension 3000 PC Desktop Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
