I have a sony wega 50" tv which i replaced the screen lamp and the tv still don't have sound or picture
SOURCE: Lamp Replacement on Sony Wega TV
You can save some $$ by replacing only the bulb. Cost of bulb with housing is $250, bulb only is about half that. See how here:
http://www.geocities.com/bob_lipp/Instructions.html
SOURCE: Sony WEGA 50 turning off every 30 seconds
The protection circuit is cutting in and out and it is really just a high current detection system.
This is very typical of loose connections and cold solder joints which are easily diagnosed by giving the set a whack with your hand in a few strategic places.
Also check the fuse on the power supply board .
SOURCE: replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
SOURCE: I am trying to replace the tv lamp on Sony Wega 50
I had the same question my Sony 50 bulb is in the front bottom siver panel where the green / red light the whole panel pops off
