The voltages are located on a sticker on the back of the PDP panel itself. Each panel is independant so no two sets will be alike. In most cases you can swing the vscan up or down by 10 volts to see what happens. Anymore than that can cause the set to shut down.
They mean... Vs = usually to do with Volts, usually denoting Vss, or Ground... Can also mean Voltage on the Source of a FET transistor. Vscan, = Scan Voltage. Vset, = Set the Scan Voltage, Ve, = Voltage again usually Vce meaning Positive Volts,. Can also mean Voltage ON the Emitter of a Transistor. But unless one can see the place in the circuit on the schematic, it is hard to tell.
