Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
The phone could have hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
