I have a Technics SL-B205 turntable that runs too slow - even with pitch control all the way up. I have replaced the belt. Motor seems to run smoothly/quietly, What else to do?
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
You just need a new belt, they're around 20 bucks. Buy them in pairs, or threes. They stretch out about every seven years.
SOURCE: all my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
SOURCE: I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies
to other brands as well - however this belt is only for the Technics
models listed above:
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
