Download the drivers from logitech
http://www.logitech.com/index.cfm/support_downloads/&cl=ca,en
Hello
place batteries in mouse.
connect The Transmitter/reciever to the pc ( probably USB) and then press the sync button under the sender if there is one, and then press the sync button under the mouse.
windows should recognize it.
To get the driver search for your model on the manufacturer's website
and download the driver ....install driver and plug mouse in.
If this does not work let me now what OS ( operating system ) you are running.
and what you are plugging the mouse into.
Your Logitech mouse should have come with a USB receiver that will connect to any USB port on your computer. There is no need to download any programs. Once the receiver is connected and the battery is installed in the mouse, you're good to go.
SOURCE: Cordless mouse
Just a thought, perhaps you could borrow a usb cable mouse. Tell the comp to detect the wireless mouse, then unplug the usb mouse.
SOURCE: My cordless mouse doesn't work now that I installed Vista program
Try disconnecting the mouse ,turn off the computer ,then turn plug back in the mouse and let Vista find it. If that doesn't work go to the control panel and use install new hardware.
SOURCE: MX1000 Laser Cordless Mouse, setpoint doesn't seem to work
install mouseware in the cd ,that given when you buying
SOURCE: Logitech cordless mouse problem
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
