Question about Sharp AL 1631 Copier
WE have a Sharp Al 1631 that the copy scanner won't go the full length of the document
Posted by valijane on
abbas rezazadeh
  • 328 Answers
All sharp 1631 models have this problem service scan unit guides and movement placies
Posted on Jun 01, 2010
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
My Sharp 1631 sounds like it is working fine but blank copies are now coming out
Make sure thee scanner lock isn't locked and after you clean the scanner rail, use only 3n1 oil on it.
Sep 24, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
AL 1631 - Give me blank copies, Shape tech. sadi scanner was stuck.
Hi:
If your not comfortable with disassembly then you should have it repaired by a qualified tech. With that said you need to remove the glass that you rest your documents on. Undre that you will see a round silver tubular shaft that the scanner rides along. This shaft needs to be wiped down with alcohol. The shaft can be spun around as it is cleaned. When this shaft gets dirty and black it will cause the scanner to stall and if it does not scan the document then you get a blank copy.
Andrew
May 11, 2009 | Sharp AL 1631 Copier
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Sharp al-1631 lines on copy only when original goes through docum
Clean the narrow document scanner glass to the right of the main copy glass.
Mar 11, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
