Posted on Feb 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lanier LD135. How do I program it to print
Lanier LD135. How do I program it to print envelopes?
Anonymous
Level 2:
Sniper:
  • Expert 58 Answers
  • Posted on Feb 26, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
58
Questions
0
Helped
64027
Points
131
Envelopes thru bypass only....once they are set youl need to set the bypass to envelopes at the machine either thru user tools or by pressing bypass then the # key and selecting envelope or custom size and entering the size of your envelopes.
Back at the computer go into print proprties and select paper souce bypass the printdriver will use the machine settings unless ou tell it otherwise
How to print enevelopes without them jamming in a lanier ld425c
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
LANIER LD135 CODIGO DE ERROR SC990
Depends on the associate engine code. Most of the time it means that maintenance is overdue. Otherwise, it is an electronic issue.
How do you print an address to an envelope? And can you only print #10 envelopes?
No, you can print on any envelope size. As far as addresses are concerned, you need to setup a template for the envelope size in your program. What program do you have for this function, do you have Microsoft Word or come other word processor like that?
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
1helpful
How do i print envelopes on a Lanier LP331cn laser color printer?
You should see a bypass tray near the main paper tray. On laniers it is recommended you use the bypass tray for envelopes.
when you send a print job make sure to select the bypass paper tray option
I need to get a meter reading on a Lanier LD135/145 copier.
Hello sir; You just press "user mode' it will show up "total count"
Printing envelopes
It starts with your software. You must have a program which allows you to enter info that can be formatted to print on an envelope(Word or another word processing program).
When you start a new document you tell the program what you want to do. Once the data is entered it is a simple matter of manually feeding the envelope into the printer. Envelopes should not be bent or have dogears or damaged because they can damage your printer. You may have to try the envelope a couple times until you get it fed the correct direction. Another option is to print labels using Excel and print up a whole sheet of labels at a time. Good luck.
Can't Print Envelopes from the Bypass Tray
you have to tell the printer in the print que that you are using envelopes and what size envelope.
-Carl, please let me know if this helps.
2answers
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
