Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
To fix this issue you need find the corrupt filters for the cd/dvd rom and take the registry backup. Now after registry backup is done you need to find the upper and lower filters. If you find them deleted one of them and uninstall/reinstall the drive. If that doesn't work then you need to restore the registry and delete the another filter and uninstall/reinstall the cd/dvd drive. After it is done just reboot the system and the drive will work for sure.
If you are unable to follow the solution then click on this link on "how to fix cd dvd drive not working" Issue
Best of Luck.
Hi
if your Error code is Code 29 (This device is disabled because the firmware of the device did not give it the required resources. (Code 29))
Then
Recommended resolution
Enable the device in the BIOS.
Enable the device in the BIOS of the device. For information about how to make this change, see the hardware documentation or contact the hardware vendor.
If error code is
Code 39
(Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39))
Cause
There are several causes of Code 39 errors:
* A required device driver is missing.
* A required binary file is corrupted.
* There is a problem with the file I/O process.
* A driver that is referencing an entry point in another binary file is unable to load.
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
2. Restart your computer.
3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
I hope any of this will
solve your problem
