Question about Yahoo Mail
Someone has gotten all my contacts off my computer and is sending spam and links using my email address, HELP
Posted by dcrinc2 on
Bhautesh Patel
    Guru:
  • 402 Answers
This is the main reason why you are getting all this spam email. 95% of all junk mail you get is because you gave your email address to somebody, somehow, somewhere.
Ask yourself to whom you gave your email address.
Examples to whom you disclosed your email address
Online Forums
News Groups
Sign-ups software downloads
From IRC and chat rooms
Your homepage
Your business card
White & yellow pages
Your friends!
This list only contains the main sources where you disclose your email address.
Other sources of Spam Email
Through Mail Relaying
Mail Relaying is sending mail to a user that is not local to the server you have connected to. It slows down your email and gives spammers free bandwidth.
Through dictionary attacks
This happens when spammers connect to your server and just trying random address or even stepping through the alphabet. Some servers will block the sending server after X number of failures, some set max recipients per message and others set a delay between recipients to slow down the spammer, causing them to go elsewhere.
Through the selling of e-mail addresses
Companies sell your information to other companies.
Trojans/Script capturing
By using HTML e-mails, spammers can confirm your email address. Best to disable preview window and delete the message. You can disable HTML or even block the email client from communicating on port 80.
Thanks
Have a great day.
Bhautesh
Posted on Feb 24, 2010
KYOCERA Model : TASKalfa 3011i. I cant scan to email any more ,below is the error;
  1. Open web browser and put the IP address of the printer Network Card in to the address bar.
  2. Click on the Basic link on the top and then the Address and Contact links on the left.
  3. Click on Add Contact.
  4. Under Name fill in the Contact name you want to show in the display.
  5. Under Email fill in the email address of this Contact.
  6. Then click on Submit at the bottom of the page. (To add more contacts repeat steps 3 to 6.)
  7. Click on the Network link on the right.
  8. Ensure the proper Default Gateway is set (ensure other information is also correct), if not enter it.
  9. Click Submit at the bottom of the page
  10. Click on the Scanner link at the top of the page then the Email link on the left of the page.
  11. Something should be input into the Subject and the Body to help prevent spam filters from blocking the email.
  12. Click on Submit the bottom of the page.
  13. Click on the Scanner link at the top of the page then the Email link on the left of the page.
  14. Something should be input into the Subject and the Body to help prevent spam filters from blocking the email.
  15. Click on Submit the bottom of the page.
https://www.customersupportcare.com/kyocera-printer-support.html
Have gmailaccountnot receiving mail sent to me
1) Do the parties have your correct email address. Test at least one of the parties by requesting they use the link in your email to reply to you rather than their contact list in one single email when you know they are online. If you get it from them and not the other parties, then just perhaps the others are sending to an old email address.
2) Have you searched all of your mail boxes? Sometimes a rule has been applied that filters your incoming mail and sends it to an unexpected mail box in rather than your primary mail box.
3) Have you checked your spam box. Most of us have had some mail sent to spam that was not.
4) Consider changing your password to your email.
5) Is no email coming your way or just mail from a particular party? Compose a letter to yourself and email it to your own email address. After all, no mistaking that address!
6) Have you installed any new security software? And, just maybe your own antiviral is blocking something malicious that has attached itself to an email sent your way.
7) Sometimes email gets stuck in a server somewhere on its way to you. For instance, if someone tries to send you an email with an attachment that is larger than what the email server allows, it gets stuck in their outbox and you don't get it. There may be NOTHING wrong on your end, in such a case.
1helpful
How can I limit spam mail without closing account and opening another?
Don't Post Addresses Online- Never post email addresses online such as in message boards, forums or on websites for all to see. Spammers (and Phishers) have automated processes that can 'harvest' these. If you must post it, then disguise the format (e.g. john.smithATgmailDOTcom).
- If you receive a lot of spam, a web search for your email address may reveal whether it is posted anywhere online and you can remove it.
Avoid Common, Guessable Formats- The more complicated your email address, the less likely it will become a target for spam. Spammers use software that trys to guess email addresses and a commonly used format such as [email protected] will be a greater target of attack than [email protected]
- Obviously, the trade-off is that your email address will not be quite as memorable or look as nice.
Limit Sharing of Addresses- The more you share your email address, the more spam you will receive, it is that simple.
- Never share your primary personal or work email addresses with those you don't know or trust.
Use 'Disposable' Addresses- Many stores and online services request email addresses for things like account registration, mailing lists and discounts. Set up an email address specifically for these cases, so you do not have to use your primary personal or work email address.
- When spam becomes an issue for this additional email address, simply dispose of it and set up a new one. Services such as Gmail allow you to check and send from different email addresses in one place, facilitating easy management of multiple addresses.
No Email Based Screen Names- If you participate in message boards, chatrooms, Twitter or similar where you display an on-screen name, don't use your email address before the @ sign as the screen name.
- Spammers will often take screen names and add common email endings such as @gmail.com, @yahoo.com and @hotmail.com, in order to guess legitimate email addresses.
Delete without Opening- It is often obvious from the subject line that an email is spam.
- Simply add the sender to your spam filter and delete the email without even opening it. If you do not open it, there is no possibility of the spammer being informed that your email account is active.
Disable Automatic Content Downloads
- Automatically downloading images or other dynamic content in emails might make them look nice, but can reveal to the spammer that your email account is active.
- As a minimum, turn off automatic image downloads in your emails until you are sure the email is trusted and not spam or a phishing email. Specifying to read messages in plain text only will add a further level of security, as all dynamic content will be blocked from download.
Don't Forward Spam- Be wary of emails from anyone asking you to forward the email on, such as petition, chain or joke emails. By forwarding these emails, you are effectively spamming others.
- In addition, these emails are used by spammers to obtain legitimate email addresses for spamming, as they contain the email address of everyone who has forwarded the message along with the addresses of everyone each person forwarded it to.
Never Reply or Click the Links- Clicking links, including the ubiquitous 'unsubscribe' link, in spam emails or replying to spam, will confirm to the spammer that your email account is active, resulting in more spam being received. It may also direct you to a website that contains malware.
- Never reply to spam and avoid clicking links in spam emails. Only click the 'unsubscribe' link for marketing emails you remember signing up for.
Never Purchase anything from Spam- Don't fall for products or services advertised in spam emails, no matter how good they may sound. If it sounds too good to be true, it usually is.
- Buying something advertised in spam only supports the case for spamming and will likely increase the amount of spam you receive, as the spammers now know you are willing to buy.
Avoid Opting In- When purchasing or registering something online, there are usually one or more checkboxes allowing you to opt out of marketing communications or sharing of your information with other 'partners'. If you opt in, you may be opting in to a lot of future spam.
- Always read the opt-out messages with care, as these are cleverly worded to get you to opt-in. Some of them require either selection or de-selection to opt out, whilst others require a mix of selection and de-selection to fully opt out!
Read Privacy Policies- Always read the website's privacy policy before purchasing products or registering your details for software or services online.
- Understand how your email address may be used and whether they can share or sell it to other third parties, who could be spammers.
Use a Spam filter- Activate Phishing and Spam filters on your email account and in your Internet browser to help ensure you avoid receiving spam in the first place.
- Most reputable email service providers will have spam filters that you can turn on, some of which allow very granular policies to be set.
Report Spam- Report spam that does slip through the net to your email service provider or your company, as applicable.
- This will add the sender to their spam filters, identify whether spam filter policies need to be updated and will block future spam from that sender appearing in your inbox again. Reporting spam can also result in the spammer being identified and criminally prosecuted.
Keep Anti-Virus Software Updated- Ensure your anti-virus software is kept up to date and download the latest signatures on a daily basis.
- A lot of malware is designed to access your email contacts and send spam or malware to them from your email account without you even realising.
If it all gets too much...- Finally, if the amount of spam becomes too much to control, you may simply have to start again and obtain a new email address.
- Monitor the old email account in parallel to ensure that all legitimate contacts have your new email address, then delete the old one.
Strange emails in gmail
Most likely someone you have sent an email to in the past has had their computer hacked, exposing your email address, and now your email address is on a distribution list.
Nothing you can really do about this but mark as spam and possibly set up a gmail filter with some consistent common feature in the subject or message to always send them to spam or trash.
7helpful
My yahoo account has been hacked and is sending spam to my contacts. I am now being band from using yahoo groups
You need to contact Yahoo. If you can change your password that will stop anyone else from using it. Make sure you also change your security questions as the hacker may have the current answers.
Once you have taken control of your account, then contact Yahoo and see if they can lift the ban. If it is just a case of someone has gotten your contact list and is spoofing your email address, there is almost nothing that can be done about that and should be a cause of a ban.
Best of luck, Jim
Mar 08, 2011 • Yahoo Mail
Someone has gotten into my yahoo mail account and is sending out mass mailings to individuals in my directory. How do I cancel and stop my present email address.
I would first go in and change the password on the account... And I think you need to contact Yahoo inorder to cancel the account. My account was hacked about 2 yrs ago and it was sending out adult links to tons of people. But all I did was change the password and scanned my computer for any infections.
here is a link to cancel your account if you choose this option.
http://help.yahoo.com/l/us/yahoo/edit/changing_users/edit-23.html
Best of luck...
Nov 22, 2010 • Yahoo Mail
2helpful
2answers
I dont know how to verify my email
Usually, when a website wants to verify your email account, they will send you an email with a link to click on or a code to enter somewhere on their website. If you did not receive this email, check your spam folder.
Someone is sending emails to all of my contacts and it is not me...how do I make this stop, short of closing my yahoo account... my email address is [email protected] if this cannot be...
There are chances that someone has knows your password and is sending mails from your email id. Check your sent folder to find out if someone has sent mail from your email id.
Or
Someone is using spam email ( third party ) and enter your email id in from field and sending the mails.
Click here to deactivate your yahoo account
Oct 06, 2010 • Yahoo Mail
2answers
Someone is sending email using my aol address. Some are from my address book and list no Subject, they heve no message. Many many others are sent and not are not delivered but returned to me with message...
Barb
I would contact AOL and tell them what's been going on. It's possible that someone guessed your password without using a spy program. I haven't used AOL in a few years, but here is where you can get their contact information. I'm surprised Norton didn't tell you that. Good luck, hope it's just someone messing around and nothing serious.
2answers
Yahoo Mail Logo
Top Yahoo Computers & Internet Experts
Randy Prevost
Randy Prevost
Mike
Ekse
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
