Question about Olympus Camedia C-720 Ultra Zoom Digital Camera
Do the red lights on the charger change color or
Do the red lights on the Instant Replay charger change color or turn off when the batteries are fully charged?
  • 239 Answers
User manual of Olympus Camedia C-720 does not mention about overcharging.
But a small part of manual gives the below knowledge.
This is not a solution you demand. But may be a little will help your battery question.
Posted on Feb 24, 2010
Nikon COOLPIX s3300 replay button does not work. No damage. Just stopped working.
Replay will give a WARNING NO IMAGES. This is confusing. I can think of nothing to do. Turn it off off remove Batteries. Put batteries back in an CHARGE IT... Make sure it is FULLY CHARGED. Then Remove from charger and turn on and take a photo Does REPLAY WORK?
Dec 04, 2016 | Nikon Coolpix S3300
There's a batterie light flashing what does it
When you connect your laptop to a power source to charge it using a charger, the battery light will start to flash in RED color. It will turn to GREEN when your laptop is fully charged, so you can remove your charger from the power source.
Jun 15, 2013 | Computers & Internet
I need to READ the battery charger instructions for a Minolta Dimage G500?
I suggest you charge the battery overnight and in the morning if the LED does not change color then the Red LED on the charger only indicates that there is mains power to the charge adapter.
Jul 11, 2012 | Konica Minolta DiMAGE G500 Digital Camera
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Mar 26, 2011 | Nikon EN-EL1 Battery + Charger...
Battery charging
Usually when the light on the charger either changes from red to green, or some chargers have a blinking light, when it stops blinking. I have seen chargers which also had a light which would turn off when the battery is charged.
Apr 12, 2010 | Fuji FinePix J10 Digital Camera
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Nov 27, 2008 | Duracell NiMH AA/AAA Battery Charger with...
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
Olympus Camedia C-720 Ultra Zoom Digital Camera Logo
83 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
