Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
Posted on Feb 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the soap plunger is placed into the container of soap it does not dispense the soap but it will dispense water if placed in a glass of water
Robert Koch
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 165 Answers
  • Posted on Feb 28, 2010
Robert Koch
Expert
Level 2:
Mentor:
Answers
165
Questions
0
Helped
72233
Points
244
Try adding small amount of water to the soap to thin it down so pump will work.
How do I fix the problem with water spraying out the hose that's for the soap?
the warbler is just a cam action for the pump plungers so there will be no timing
I would think that you have the spring on the wrong side of the valve for the soap line and instead of shutting off that line when using the pressure wand it is by-passing pressure up that line to the dispenser.
It should be a one way valve to work under low pressure from the dispenser.
Sep 13, 2015 • Garden
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 • Dishwashers
Soap dispenser lid doesn't open
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Water is coming up through the kitchen sink when dishwasher is running and teh soap depenser will not release the soap.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these. Please do rate this solution and revert for further assistance.
Daniel
4helpful
2answers
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
2helpful
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 • Plumbing
Whirpool washer fabric softener container
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Our dish soap is not dispensing from the flip container.
sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
4helpful
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
4answers
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
