It's driver related problem,
to be solved, please visit this webpage and follow the instructions: Driver Update Software for XP Vista 7 8. enjoy
Go to Control Panel\All Control Panel Items\Devices and Printers and right click and look at menu. click on start scan.
Download driver here: http://canoncanada.custhelp.com/app/answers/detail/a_id/16910/~/imageclass-mf3200-series-printer-driver-ver.3.00-for-windows-xp/vista/windows-7 Do not connect the USB cable until after you have loaded the downloaded files. 1. download files 2. Downloaded files are saved in .exe format. 3. decompress them. A new folder will be created in the same folder. 4. Click on "Start" button in Windows, then click on "Devices and Printers" 5. Click on the button "Add a Printer" at the top of the Devices and Printers screen 6. Click on "Add a local printer" button 7. Make sure that "Use Existing Port" is selected as an option and beside that, where it says "LPT1: (Printer Port)", a) change that to USB001 if no other printers have been previously installed - then click "Next" b) if other printers have been installed, check which USB port number is the highest and pick the one above. (ie. one Canon has been installed previous to MF3240 and is USB001, then pick USB002) - then click "Next" 8. Click "Have Disk" button on Install Printer Driver page 9. Click "Browse" button on Install From Disk 10. Find the folder where the download has decompressed to (in Step 3) and click the "open" button 11. Click "OK" on install from disk 12. Click to select the MF3200 printer and click "Next" 13. Follow the on screen instructions.
I have XPx64 and i am trying to download the driver from teh cannon website but its not downlaoding. Please help me out.
A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
