This was copied from the Pioneer support site:
Clock adjustment is performed in the "Initial Settings" menu.
Please follow the instructions below to access time setting.
Press
& Hold [OFF]
Pres & Hold [Muti-Control] until "Clock Set"
Appears
Turn [Muti-Control] to choose setting
Press
[Muti-Control] to enter setting
Time Setting:
Press
[Muti-Control] to select time setting mode
Press [Muti-Control] to
select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segments
Available
functions:
Clock Set, Warn Tone, AUX 1, AUX 2, SW Control, Ever
Scroll, BT Audio*, Pin Code Input*, BT Ver Info*
*Available only
when bluetooth adaptor is connected
SOURCE: setting clock on my pioneer deh 1400
the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
SOURCE: setting clock on pionerr deh-p3500
try www.pioneerusa.com you can download the manual for this model -----
SOURCE: I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Totally worked on my pioneer radio- ive been trying to figure out the time adjustment feature for months....thanks!
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
