Question about Panasonic Office Equipment & Supplies
Using the fax machine of Panasonic KX FT981, How can I add a contact (including its number) into the phonebook?
Posted by dang_thenghi on
Anonymous
    New Friend:
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Posted on Apr 01, 2011
Hafiz Umer Daraz Khan
How to set and use KX-ft981 fax machine and how to check sending records
Posted on Sep 13, 2021
Anonymous
    New Friend:
  • 54 Answers
Press menu unit displayed phone book then press set
Posted on Mar 03, 2010
I have a KX-T7433 and would like to change the number of rings before it goes to voice mail. It is currently set at 4 rings and would like to change it to 6
The KX-T7433 isn't an answering machine. If the voicemails are going to an answering machine you have on the phone line, consult its manual. If the voicemails are going on to your telephone service provider's system, look for instructions in the phonebook, or contact the provider.
If you need a KX-T7433 manual, you may download a copy at Panasonic KX T7433 Phone User Manuals Guides
6helpful
Can I add more than 50 contacts on my Panasonic KX-TGA242
Sorry, the KX-TGA242 is limited to 50 contacts in its internal phonebook.
2answers
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Problems with panasonic kx-ft981 fax machine
my panasonic kx-ft981 get trouble with paper jam, i change with different paper fax it still paper jam... plz help
Panasonic KX-FT981 our Fax phone has no ink any more. where do we get ink and hoe to put it in the fax phone?
Maybe I'm missing something here, but your machine appears to have a thermal printer. If this is so, there is no ink to replace. One simply buys a roll of thermal printer paper from your office supply store, or order it online. A search for 8.5 inch thermal paper turns up several listings for the paper. If this is another type machine, sorry.
12helpful
Panasonic fax model KX-FT981
the machine showing memory full . how clean memory
No possibility to send a fax and ''replce drum'' shows
Contact a local Panasonic supplier for a replacement drum...when the display is corrected the machine should work.
1helpful
How to add calling card 800# and PIN to expedite LD calling.
When storing a calling card access number and your PIN in the
phonebook as one phonebook item, press {PAUSE} to add pauses after the number and PIN as necessary. Or, if stored as separate entries, during a call, press MENU, press 1 to select “Phonebook”, and scroll up or down to find the entry and press Call. Repeat to dial other numbers.
1helpful
Retrieve messages away from home on a Panasonic KX-FPG381
You have to set a polling number, you WILL need a manual. Use your keypad just enter this number when you phone home
Top Panasonic Office Equipment & Supplies Experts
Ekse
Alvin Barnabas
Alvin Barnabas
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
