Question about UTStarcom Cell Phones
I have a UTStarcom Shuttle. I am trying to play to play music
I have a UTStarcom Shuttle. I am trying to play music from external memory but phone media player connot find the music. User manual says they have to be in the main root directory or in my music folder. Media player will not run because there are no music files. When I try to play music it says No contents exist. Thanks
Posted by adr7704 on
Anonymous
    New Friend:
Put a microSD memory card (limit 4GB) in the phone. Take a few pictures and make a short video .Use the phone menu to transfer the pictures an video to the external memory card. Use the media player to watch your recorded video. Try to play music and you will get a no content found message. Now, turn off the phone, remove the memory card and place it into an adapter that will connect to a computer by usb port. Windows should recognize it as a removable drive. If you look at that drive in Explorer you will see 3 folders. Pictures are in my_pix. Videos are in my_flix. Transfer .mp3 files to the my_music folder. When you put the card back into the phone you can play the mp3 files with the media player. Yes, I did this and it works.
Posted on Jan 08, 2011
When I am listening to music on my Huawei Y536A1 through headphones, every so often the music stops eor about 5 to 10 secs and then starts up again. Ive tried changing a few different settings and nothing...
Have the same phone and d same prob. Tried downloading other music players from Google play store with no success. Finally settled on shuttle music player with no success. I noticed that the problem happened after the screen for the music player and the phone went to sleep to conserve the battery. I went into the settings for shuttle music player and changed the screen settings to never sleep or lock. I went into the phone settings and changed those screen settings to not lock for the maximum time, 30 minutes. Since doing that, I have had no problems with music player. Frustration has ended. Here's hoping you still have the phone, and that this works. I won't charge you 10 US dollars for this information. Good luck! :-)
Mar 03, 2015 | Huawei Cell Phones
Hi this is vijay my probelm is when i open music player it shows not enough memory but the song plays and i cannot see vedio or playlist while song was playing
It may be due to too less free phone memory.. As to run the application there must be sufficient phone memory..Try transfering the files which u saved on your phone memory to external memory..
Jan 03, 2011 | Nokia 5220 XpressMusic Cellular Phone
When i play music at my nokia 6300,this is always shown[ music files not found] what the best solution in this problem.
Place the music on music folder, also use the format that supported by your phone. Also try to place the music on your phone memory, if detected then it should be your external memory problem.
Mar 05, 2010 | Nokia 6300 Cell Phone
Cant transfer music files from card to phone or find them.
I had the same problem and realised that you have to copy the file from the music section on your external memory to the sounds section. Firstly I sent an album to my memory card via windows media player and it went to the music section. My phone recongnised it was there on the external memory but not when I tried to play it through the mp3. I read an earlier message and it mentioned that the music needs to go into the sounds file so I copied it to that file and hey presto, I have music on my external memory that actually plays lol
Jun 18, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
My LG KF700 wont let me send picture messages or play music
You have to move all the stuff from internal memory onto external memory and this will then work for you. And should no longer say it is full. Follow >>
menu> my stuff> sounds OR images> click the sound OR images you want to move over by clicking option> file> move to external
Apr 05, 2009 | LG KF600 3MP InteractPad Triband Phone...
LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Feb 23, 2009 | LG Shine KE970 Cellular Phone
Forgot lock code for utstarcom shuttle
press ## v i r g i n #. That will reset the phone. your lock code will be the last four of your phone number. it won't delete anything you downloaded, nor will it delete your phonebook.
Feb 06, 2009 | UTStarcom Cell Phones
Playing MP3 from external memory
u can make a new playlist and try if it works
May 26, 2008 | LG Shine KE970 Cellular Phone
Getting songs from the sd card to show on my phone
To find your music on the SD, go to my stuff, sounds, external memory, mp3 and you should see your music. Playing it, however is another matter. You can play only one song. Then you have to manually play the next one. Not what I'd call an MP3 player.
Mar 07, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
104 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
