What are the most recent road maps for the Garmin GPS V? I have Garmin City Select v6 with the v7 update and I can't seem to find any newer road maps for my GPS V.
If you want to test the maps on your new Garmin you can do one of two things. Either you can copy the maps onto an SD card and then insert the card into your GPS. You can also connect the GPS to your computer with the USB cable that was supplied with you unit. Using whatever file manager you normally use with your version of Windows (Windows Explorer, Total Commander, etc), you will be able to see your Garmin GPS as another drive on your system. You can then copy your City Select maps over to your Garmin.
Once you have the maps either directly on your Garmin GPS or on a microSD card, you have to choose to use those maps. From the main screen of your GPS choose Tools>Settings>Map. If your City Select maps are compatible with your GPS they will show up in the list of maps. To make use of the map just choose it by touching the name of the map. Your Garmin will then load that map and display it. If your City Select maps do not show up in the list, or if you choose them and they do not load or give you an error then they are not compatible with your 1490T.
If you need anymore information or help please let me know. Thank you.
Try connecting it to your computer via a USB cable. Then log on to Garmin's webiste and download a map update. Then you can put the map update on your GPS to replace the ones you lost. All Garmin customers get one free map update. After than it's about $40-$60 dollars for an update.
You can update the maps using either Garmin or other third party maps. The accuracy will depend on how old the mapping data was that is used to create the map. So you want to find out if the map in that area is recently updated. You may also find that a regional map may show the details in some areas where a larger map won't.
To upgrade using Garmin you just go to garmins website
http://www8.garmin.com/updatemaps/
You may find the map update is free or you may update for a fee or get a lifetime update subscription. The gps is hooked up through the usb cable and will download and instal the updates. It's painless (sort of ;-]) and quick.
It depends on the specific model you bought and whether detailed maps were included. In most cases, a "general" map is included for free, but the free map is usually not detailed (no roads or only MAJOR roads, like interstate, but no city streets).
In most cases, YES you will to buy separate maps for your handheld Garmin GPS.
The Garmin GPS are among the easiest to use and they have the most complete mapping on the market. To update the mapping, there are several versions of the software integrated into these road gps. To name a few, city navigator version 8 and City Navigator 2008. With a newer version, you have the most recently built streets, new shops, new parking lots, etc.. To update, there are several ways to proceed. First, before you update your maps, I recommend you check if there is a newer version of the maps, visit garmin and download the plugin. You can also view the maps version directly on your gps.
Did you buy the unlock key from garmin? You need this key to be able to use the maps on a specific gps (serial number) so when you update maps, you type in this unlock key and the maps are unlocked on the gps. There is a page about this on the garmin website
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for "Map Info", select Map Info. Verify that there is a check mark next to City Navigator North America NT
